Is it possible for DHCP Clients to get IP in this scenario
netadmindha
    Dear Experts,
I  would like to share you my requirement as follows  -
Current setup :
Core-switch :  Lan protocol - Eigrp , Connected to Access-switches via trunk, Spanning Treee Root & VTP server.
Layer 2 vlans, DHCP Scope Layer 3 vlans configured with helper address.
Now we want to deploy Distribution switch between  Core and Access Layer as follows
I donot want to make much changes to my networks thus only bring layer 2 sepearation from Core-switch which prevents STP loops for ever
from any access-switches.
Query1 : Does my host ( PC's or wireless device ) connected to access switches to receive dynamic IP-address from DHCP scope configured on Core-switch ?
Query2 :  Incase if above question answer is  "NO"  .....If i just configure DHCP scope for each subnet and their relevant  Layer 2vlans ..
Does my Host will receive Dynamic IP-address from Distribution switch .
Query 3 :  If my hosts obtain as per query 2 ...do they able to ping the gateway and other subnets ?
Sample config  : -
Core-switch 1
interface Vlan7
description HQ_Users_VLAN2
ip address 10.1.2.2 255.255.255.0
no ip route-cache cef
standby 7 ip 10.1.2.1
standby 7 priority 110
standby 7 preempt
standby 7 name HQ_Users_VLAN2
interface Vlan242
ip address 10.1.242.2 255.255.255.0
no ip redirects
delay 100
no ipv6 mld snooping
standby 242 ip 10.1.242.1
standby 242 priority 110
standby 242 preempt
Distribution switch :
#config t
vlan 7   ( Does Dist.switch required Layer 3 vlan  for vlan 7 and vlan 242 such that host in access-switch gets ip-address and
Vlan 242            communicate to default gw and other vlans. )
ip dhcp pool DHCP2
   network 10.1.242.0 255.255.255.0
   default-router 10.1.242.1
   lease 90
ip dhcp pool DHCP1
   network 10.1.2.0 255.255.255.0
   default-router 10.1.2.1
   lease 90
Access-sw1:
Int fa 0/1
sw acc vl 7
Access-sw2:
Int fa 0/1
sw acc vl 242
Attached the network digram for reference
Request you to please provide your valuable suggesstions
Akber Mirza.
2 Accepted Solutions
Joe Lentine
I really need a more clear explanation of your physical connectivity. Please copy in the whole configs from the switches and label what is connected to what. Also please submit a show ip route and show ip route eigrp
If you want to put Distribution switch between access switch and core, and act like L2 device then you do not need to configure DHCP helper address and SVIs on it. Just connect it to access and core via trunk. In this way core will be default gateway and HSRP failover with SVIs and DHCP pools.
But if you want L3 separation between distribution and core then you need to configure SVIs on it and it will be default gateway for hosts. DHCP pools you can configure either on core or distribution.
First it will be better if you tell what exactly you want to achieve. I would select second option with HSRP failover if you have at least two distribution switch.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
10 Replies 10
netadmindha
Dear Experts,
Please give your valuable inputs  at the earliest.
Appreciate your quick response.
Joe Lentine
Ok first off I'm not sure if you are looking to route from your distribution layer as typical hierarchal designs suggest. That's what i would recommend.
-So your distribution switch would be the gateways for you vlans . Configure dhcp scopes on distribution switch without helper addresses. You do not need them on a layer 3 switch if it is directly handing addresses. Then setup eigrp and configure your networks in it. Then set it up on your core also. Make sure you either propagate a default route into the eigrp domain, or configure it statically.
I hope this helps. Feel free to ask more questions
Abzal
Level 7
Level 7
1. Yes, it's possible. However to make it work you need to configure DHCP relay on distr. switch.
Suppose g1/0/1 is interface connected to core and it's IP 10.100.0.1. And vlan 10  is Data VLAN, vlan 30 Voice VLAN
int vlan 10
ip helper-address 10.100.0.1
int vlan 30
2. No distr. switch does require it. Just make sure that your SVIs for Data and Voice are on the same subnet as on DHCP scope configuration.
http://www.cisco.com/en/US/docs/ios/12_4t/ip_addr/configuration/guide/htdhcpre.html
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Currently i have my DHCP Scope configured on my Core-switch  and access-switch directly connected to it by Trunk.
Now i am planning to bring Distribution switch between Core and access layer.
Current Core-switch :  Lan protocol - Eigrp , Connected to Access-switches via trunk, Spanning Treee Root & VTP server.Layer 2 vlans, DHCP Scope Layer 3 vlans configured with helper address.
Distribution switch ROLE will be : -
Distribution switch will be connected with L3 connectvity    (ex10.1.130.1  ---- 10.1.130.2) to Core-swtitch .
My Question can we send DHCP host UDP broadcast  over a layer 3 connectivity from DIStribution to core-sw?
as per your above suggesstion
You want me to configute as below  ?
Core-switch   will remain the Layer 3 subnet  and DHCP scope for VLAN 7 ( example)
Disctribution -sw:
Int vlan 7
ip helper-address 10.1.130.2 255.255.255.0
( does this vlan 7 not required an ip address again from same
Commands ++++++++++++++++++++++++++++++++++++
Core-switch 1
interface Vlan7
standby 7 preempt
end
ip dhcp pool DHCP1
   lease 90
#config t
vlan 7
Int vlan 7
no shut
Access-sw1:
Int fa 0/1
sw acc vl 7
Akber Mirza.
I don't understand your above configuration, but let me try explain.
You have two options here:
1. Make L3 core switch default gateway for hosts with HSRP. Distribution and access will be L2 and connected via trunk.
Then you could configure DHCP on the core. No additional configuration needed.
2. L3 core switch and L3 distribution switch. Connected via L3 link. You could configure DHCP on  either Core or distribution switch. But on distribution you will need ip helper-address pointing to Core. Because as you know DHCP request is broadcast packet. And distribtuion switch will be default gateway for hosts. Access switch will be connected via trunk to distribution.
I prefer 2nd option because you reduce STP tree. Also if you run dynamic routing protocol it will give redundant paths and fast convergence.
Access:
int f0/1
switchport mode access
switchport access vlan 7
Distribution:
int vlan 7
ip add 10.0.0.1 255.255.255.0
ip helper-address 10.1.1.1
int g1/0/1
no switchport
ip add 10.1.1.2 255.255.255.252
Core:
int g1/0/1
no switchport
ip add 10.1.1.1 255.255.255.252
ip dhcp pool DHCP
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   lease 90
You can configure DHCP on either core or distribtuion. If on core you will need ip helper address pointing to core.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
I tried your recommendation and achieved some part of my requirement.
My current setup:
Core-switch :
interface Vlan7
standby 7 preempt
end
ip dhcp pool DHCP1
   lease 90
router eigrp 1
no auto-summary
network 10.0.0.0
New Deployement  ( Distributionswitch) :-
Int vlan 7
ip add 10.1.2.5 255.255.255.0
no shut
ip helper-address 10.1.131.1  ( this core-swi ip which is conecting to Distr-swi L3 interface 10.1.131.2)
router eigrp 1
no auto-summary
network 10.0.0.0
Access:
int f0/1
with this setup i am able to get DHCP IP on hosts connected to access-sw and able to ping till 10.1.2.5.
Problem : host from access-sw not able to ping 10.1.2.1 ( core-sw ip) and from distr-switch also i am not able to ping 10.1.2.1 .
Also i see that my distr-sw 4900 has limitation with Eigrp as it allows Eigrp stub and hence can  i just use the following command on dist-sw.
ip route 0.0.0.0 0.0.0.0 10.1.131.1 ( core-sw int ip connected to dist-sw interface 10.1.131.2)
Please help with your valuable inputs !
Thanks and Regards,
Akber Mirza.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Joe Lentine
Did your eigrp neighbors establish?
Do a show ip eigrp neighbors to check. If they did then you should have a route to your core. Make sure your switch has the gateway to 10.2.2.5 (distribution) and make sure you can ping your core from your distribution switch. Also make sure you redistribute a default route to your distribution layer to your ISP , without broadcasting your ISP route.
Yes , Eigrp adjacnecy forming between Dist and Core switches.However host at access-sw  not able to ping  core switch ip-addres
Can you please above commment in detail ...and let me know whether the scenario will work or not?
Appreciate your posts
Akber Mirza.
Joe Lentine
