Port Channel Between Two 3560s flashing orange lights
dbuckley77
We have a pagp port channel set up between two 3560 switches.  One of the switches shows the port channel in blocking for one of our vlans and the leds' for these ports are flashing orange.  There are no duplex or speed mismatches.  Is the STP blocking causing this?
Hi!
Hmmm... I cannot really guarantee you that until you give us the show spanning-tree VLAN 7 output from both switches.
However, I am almost certain this is not a critical problem that could impact your network.
Regards!
6 Replies 6
Reza Sharifi
Can you provide "sh run" from both switches and also the output of "sh ether-chan summary"?
Switch1
DPW-SAN1-3560#sh run
Building configuration...
Current configuration : 17280 bytes
! No configuration change since last restart
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
hostname DPW-SAN1-3560
boot-start-marker
boot-end-marker
username itadmin password 7 0257071A1F1F01725859590B0E
aaa new-model
aaa authentication login default group radius local
aaa authentication login CONSOLE local
aaa authorization exec default if-authenticated
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
system mtu routing 1500
vtp domain NULL
vtp mode off
udld enable
no ip domain-lookup
ip domain-name nashua.city
ip name-server 10.100.5.2
ip name-server 10.100.5.3
login on-failure
login on-success
mls qos queue-set output 1 threshold 1 150 300 100 400
mls qos queue-set output 1 threshold 2 150 300 50 400
mls qos queue-set output 1 threshold 3 150 300 50 400
mls qos queue-set output 1 threshold 4 200 300 100 400
mls qos queue-set output 1 buffers 10 20 10 60
no mls qos rewrite ip dscp
crypto pki trustpoint TP-self-signed-3340316544
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3340316544
 revocation-check none
 rsakeypair TP-self-signed-3340316544
crypto pki certificate chain TP-self-signed-3340316544
 certificate self-signed 02
  30820251 308201BA A0030201 02020102 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33333430 33313635 3434301E 170D3134 30353232 31373534
  33375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 33343033
  31363534 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BFDC 4EBF09E4 F44895C4 F3100EBF 0366D72B E77605A9 CB549B85 D1BA81DD
  DD21F7D6 E8266C3E 15A5E6AD EC409762 50739A6A C89208D1 4DD70152 867028F8
  B491D67C D7DF48DA 2ABE71BD 57ACEC25 03B21203 CB33DF66 F69342B4 0B27B175
  EACD7E6E 66939F54 0EE09690 21F30CED 5B499E2F 0FD49D03 0EF34A75 14D43A49
  B2C30203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603
  551D1104 1D301B82 19445057 2D53414E 312D3335 36302E6E 61736875 612E6369
  7479301F 0603551D 23041830 1680146A E7EA21A4 4BB57042 384D3635 26BDEF03
  E11C8A30 1D060355 1D0E0416 04146AE7 EA21A44B B5704238 4D363526 BDEF03E1
  1C8A300D 06092A86 4886F70D 01010405 00038181 002BA849 1900988F 0A906A29
  15BA1E0E F2E21D60 97FF4580 C12498DB 16E8F402 71C06B8B D08FAB3D 3658E8BD
  37393839 6BA8A7C3 79B246CB 678E450B 5F78F0D5 3FA613C7 4FFB14E2 C4896EF6
  B70F7865 8C415D6D 4282E079 D6136D29 FEF4E491 F36CE273 7F2E304E 53EDB3AE
  5937E1DF FAF99AC4 BD437B83 4201A2CE B9473396 03
        quit
spanning-tree mode rapid-pvst
spanning-tree vlan 7 priority 16384
vlan internal allocation policy ascending
vlan 7
 name SAN
interface Port-channel4
 description p-Chan-to-DPW-SAN2
 switchport access vlan 7
 switchport mode access
interface GigabitEthernet0/1
 description P-Chan-4-dpw-san2
 channel-group 4 mode desirable
interface GigabitEthernet0/2
 description LAN1 SYNOLOGY rack-server
 switchport nonegotiate
 spanning-tree portfast
interface GigabitEthernet0/3
 snmp trap mac-notification change added
 snmp trap mac-notification change removed
interface GigabitEthernet0/4
 shutdown
interface GigabitEthernet0/5
 arp timeout 180
interface GigabitEthernet0/6
 arp timeout 180
interface GigabitEthernet0/7
 description Synology NIC 1
 arp timeout 180
interface GigabitEthernet0/8
 arp timeout 180
interface GigabitEthernet0/9
 arp timeout 180
interface GigabitEthernet0/10
 arp timeout 180
interface GigabitEthernet0/11
 arp timeout 180
interface GigabitEthernet0/12
 arp timeout 180
interface GigabitEthernet0/13
 description LH-P4500 Node 10.100.7.8 NIC 1
 speed 1000
 duplex full
 flowcontrol receive desired
 arp timeout 180
interface GigabitEthernet0/14
 arp timeout 180
 spanning-tree bpduguard enable
interface GigabitEthernet0/15
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/16
 description DPWVM3 vmnic5
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/17
 arp timeout 180
interface GigabitEthernet0/18
 arp timeout 180
interface GigabitEthernet0/19
 arp timeout 180
interface GigabitEthernet0/20
 arp timeout 180
interface GigabitEthernet0/21
 arp timeout 180
interface GigabitEthernet0/22
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/23
 arp timeout 180
interface GigabitEthernet0/24
 arp timeout 180
interface GigabitEthernet0/25
 arp timeout 180
interface GigabitEthernet0/26
 arp timeout 180
interface GigabitEthernet0/27
 arp timeout 180
interface GigabitEthernet0/28
 arp timeout 180
interface GigabitEthernet0/29
 description LH-P4500 Node 10.100.7.10 NIC 1
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/30
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/31
 description LeftHand Node 10.100.7.14 NIC 1
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/32
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/33
 arp timeout 180
interface GigabitEthernet0/34
 description DPWVM1 HP2 vmnic1
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/35
 arp timeout 180
interface GigabitEthernet0/36
 switchport trunk native vlan 2
 switchport mode trunk
 arp timeout 180
interface GigabitEthernet0/37
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/38
 arp timeout 180
interface GigabitEthernet0/39
 arp timeout 180
interface GigabitEthernet0/40
 description DPW-Backup2 SAN Interface
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/41
 description LeftHand Node 10.100.7.16 NIC 1
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/42
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/43
 description LeftHand Node 10.100.7.18 NIC 1
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/44
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/45
 description DPW-Backup3
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/46
 description DPWVM2 IntelD vmnic5
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/47
 description lefthand node 10.100.7.12 NIC 1
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/48
 speed 1000
 duplex full
 arp timeout 180
interface GigabitEthernet0/49
 arp timeout 180
interface GigabitEthernet0/50
 arp timeout 180
interface GigabitEthernet0/51
 arp timeout 180
interface GigabitEthernet0/52
 description CH-SAN1-NX3K
 switchport trunk allowed vlan 7
 arp timeout 180
interface Vlan1
 no ip address
 no ip route-cache cef
 no ip route-cache
 shutdown
interface Vlan2
 no ip address
interface Vlan7
 ip address 10.100.7.93 255.255.255.0
ip default-gateway 10.100.7.1
no ip http server
ip http access-class 5
ip http authentication local
ip http secure-server
logging esm config
logging trap notifications
logging origin-id hostname
logging 10.100.6.56
access-list 5 permit 10.100.5.114
access-list 5 permit 10.100.5.40
access-list 5 permit 10.100.6.11
access-list 5 permit 10.100.6.25
access-list 5 permit 10.100.6.30
access-list 5 permit 10.100.6.20
access-list 5 permit 10.100.6.23
access-list 5 permit 10.100.2.0 0.0.0.255
access-list 5 permit 10.100.95.0 0.0.0.255
access-list 5 permit 10.100.7.0 0.0.0.255
snmp-server engineID local 00000009020000021658E180
snmp-server community cw2000anyone RO
snmp-server enable traps snmp authentication coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps hsrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps ipsla
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 10.100.6.22 cw2000anyone
radius server RADIUS
 address ipv4 10.100.5.5 auth-port 1812 acct-port 1813
 key 7 000A33150C4E2B340E25455B1A
banner login ^C
City of Nashua Property - Authorized Users Only
Un-authorized tampering with this equipment is punishable by law
Do not attempt to login if you are not authorized
'^C
line con 0
 login authentication CONSOLE
 stopbits 1
line vty 0 4
 access-class 5 in
 privilege level 15
 transport input ssh
line vty 5 15
 transport input none
ntp server 10.100.2.253
mac address-table notification change interval 30
mac address-table notification change history-size 100
mac address-table notification mac-move
mac address-table notification threshold
end
DPW-SAN1-3560# sh ether-ch
DPW-SAN1-3560# sh etherchannel sum
DPW-SAN1-3560# sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
4      Po4(SU)         PAgP      Gi0/1(P)    Gi0/3(P)
Switch2
DPW-SAN2-3560#sh run
Current configuration : 16296 bytes
version 12.2
no service pad
hostname DPW-SAN2-3560
boot-start-marker
boot-end-marker
username itadmin password 7 040A08471B38421D1D0E550519
aaa new-model
vtp mode off
udld enable
no ip domain-lookup
login on-failure
login on-success
crypto pki trustpoint TP-self-signed-2704808192
 subject-name cn=IOS-Self-Signed-Certificate-2704808192
 rsakeypair TP-self-signed-2704808192
crypto pki certificate chain TP-self-signed-2704808192
 certificate self-signed 01
  308202A5 3082020E A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  5B312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373034 38303831 39323128 30260609 2A864886 F70D0109
  02161944 50572D53 414E322D 33353630 2E6E6173 6875612E 63697479 301E170D
  39333033 30313032 32313035 5A170D32 30303130 31303030 3030305A 305B312F
  302D0603 55040313 26494F53 2D53656C 662D5369 676E6564 2D436572 74696669
  63617465 2D323730 34383038 31393231 28302606 092A8648 86F70D01 09021619
  4450572D 53414E32 2D333536 302E6E61 73687561 2E636974 7930819F 300D0609
  2A864886 F70D0101 01050003 818D0030 81890281 8100ADC6 944C3FE2 82DF6FEF
  4B4031E3 1A6D441A ACFD0620 DD131376 9E0A44BC 97DC0D72 A8A5B8F8 8D746331
  A7E6C3D1 37B20D76 B9A59C39 1090E9DD 168C1DCE 1652D7D9 5F10AB84 DB4C83BE
  D14B78B1 BE2A189B C9F634F4 CF79FF47 02417EB2 236A2DD9 E6B16AD9 E6D4690C
  6423D52D B922DFC5 1B05BFC4 D8C0B24F 414EFC64 B24B0203 010001A3 79307730
  0F060355 1D130101 FF040530 030101FF 30240603 551D1104 1D301B82 19445057
  2D53414E 322D3335 36302E6E 61736875 612E6369 7479301F 0603551D 23041830
  1680148D 8AC1B9A5 9BA70DF4 4CEF7779 F117FA57 41383630 1D060355 1D0E0416
  04148D8A C1B9A59B A70DF44C EF7779F1 17FA5741 3836300D 06092A86 4886F70D
  01010405 00038181 00021650 F56CED49 E63A5D72 DF9E4349 AE347EB3 2B6B8D12
  12C558E9 D1735EDC D8A7CF1B A9A031CA EB84E62F 06DB2D70 0D9A17A8 B7320F3E
  1805D377 4EF787DF BDFF7ED4 3674BB0E 43F8306D 494337B4 36736A2B 23CE3257
  48EEC780 E11288FC 289DFA87 7DD5AA68 FE3B3A40 37AB353E 090757AC D4FE9356
  C61F5288 317C4B13 51
        quit
vlan 7
 description p-group-4-dpw-san1
 arp timeout 180
 shutdown
 arp timeout 180
 description Synology NIC 2
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 description DPWVM2 HP2 vmnic1
 speed 1000
 duplex full
 arp timeout 180
 description LH-P4500 Node 10.100.7.8 NIC 2
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 description DPWVM1 IntelD vmnic5
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 description LH-P4500 Node 10.100.7.10 NIC 2
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 description LeftHand Node 10.100.7.14 NIC 2
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 description DPWVM3 vmnic1
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 description LeftHand Node 10.100.7.16 NIC 2
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 description LeftHand Node 10.100.7.18 NIC 2
 speed 1000
 duplex full
 arp timeout 180
 description DPW-Backup1
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 description lefthand node 10.100.7.12 NIC 2
 speed 1000
 duplex full
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 arp timeout 180
 shutdown
 speed nonegotiate
 arp timeout 180
 description port to CH-SAN2-NX3K
 arp timeout 180
interface Vlan1
 no ip address
 shutdown
interface Vlan7
 ip address 10.100.7.94 255.255.255.0
no ip classless
no ip http server
logging esm config
logging 10.100.6.56
 key 7 0505261C29596E3B18011E0718
banner login ^C
'^C
line con 0
line vty 0 4
 access-class 5 in
 privilege level 15
 transport input ssh
line vty 5 15
end
DPW-SAN2-3560#sh eth
DPW-SAN2-3560#sh etherchannel sum
DPW-SAN2-3560#sh etherchannel summary
        d - default port
Hi!
The switch configuration seems alright (Assuming you want that Port channel to work as access) and the port channel is operating correctly.
If you are seeing one port blocked by STP in the show spanning-tree vlan 7 output then yes, the blinking LED in the switch is because of this reason, STP is blocking one side of the port-channel (The no-designated port).
Hope it helps, best regards!
JC
The port-channel appears to be functioning properly and we're having no STP issues with this vlan.  Does that mean the orange lights are a normal condition to be expected and not a cause for alarm?
Hi!
Regards!
Hello
sh spanning-tree blockedports
sh etherchannel  port-channel
Sh int Trunk
sh spanning-tree vlan x (whatever vlan is being blocked)
res
Paul
Kind Regards
Paul
