Port Channel & Channel Group
pablo.arcelcr
I setup the following
interface Port-channel1
switchport mode trunk
interface FastEthernet1/0/1
description TPCRRHR-CORE-LAN-SEC
channel-group 1 mode on
interface FastEthernet1/0/2
I two switches 3750, I connected both switches and FastEthernet1/0/1 is up and runnning but the FastEthernet1/0/2 is not showing any light, when I do a sh interfaces status this is what I get:
Fa1/0/1 TPCRRHR-CORE-LAN-S connected trunk a-full a-100 10/100BaseTX
Fa1/0/2 TPCRRHR-CORE-LAN-S notconnect 1 auto auto 10/100BaseTX
Any thoughts?
2 Accepted Solutions
InayathUlla Sharieff
Pablo,
What is connected at the other end of this 3750 ?
Fa1/0/2 TPCRRHR-CORE-LAN-S notconnect 1 auto auto 10/100BaseTX  >> it looks to me that the link is down or the other side/end is admin shutdown as this side it is showing as "notconnect" status.
First thing first:-
1- Could you default the interface to the basic config and check if the interfaces are coming up.
Ex; -conf t
        default interface range f1/0/1-2
       then do:-
show int f 1/0/1
show int f1/0/2  >> check the status it should be in up/up status.
2- Once you confirm that the layer 1 is up then shut the port down at both the end.
3- configure port-channel configuration at both the end.
4- Apply the PO config on the physical port and unshut the ports.
Hope this helps.
Inayath
Julio E. Moisa
Basically when configuring etherchannel everything must be the same, speed, duplex, kind of port, etc.
Now try to reset the interface to default  and please try again.
default interface fa1/0/1
default interface fa1/0/2
no interface po1
int range fa1/0/1-2
shut
no shutdown
* I recommend to use LaCP or PAgP instead default port-channel.
Hope it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Pablo,
First thing first:-
Ex; -conf t
       then do:-
show int f 1/0/1
Hope this helps.
Inayath
Julio E. Moisa
no interface po1
int range fa1/0/1-2
shut
no shutdown
Hope it is useful.
