01-16-2014 04:19 PM - edited 03-07-2019 05:37 PM
I am trying to connect a 2960 swith to 3560X using port channel. I have configred the switches with the following configratuion and connected them with straight ethernet cable, the link came up and then it went int err-disable state. I re-enabled the links and connected them using one cross over cable it connected and remained connected for a whole day in my lab. When I shut down both switches and took them the server room and connected both ports using cross over cable it came up and then went into err-disable state. Bellow is my configuration, can you please point out to me what I am missing: (no VTP domain configured on any of the switches)
------------------2960 configuration----------------------
interface Port-channel1
switchport trunk native vlan 999
switchport mode trunk
interface GigabitEthernet1/0/51
channel-group 1 mode on
interface GigabitEthernet1/0/52
------------------3560X configuration-------------------------------
interface GigabitEthernet0/23
interface GigabitEthernet0/24
Thank you.
01-16-2014 04:58 PM
Your condig looks good and straightthrough cable should work just fine. Can you do the following:
take the interfaces out of the portchannel
shut the portchannel
shut the interfaces
add the interfaces to the portchannel
"no sh" the PO and test again?
This should bring up the interface and the portchannel
01-16-2014 05:08 PM
Post the output to the command "sh interface status err".
