Port Channel configuration in 3945 router for LACP not working
satishpadhy
I am trying to create create a port channel in 3945 router which is connected HP Comware switch. If i put below config then router goes un reachable if both cables are connected. i tried channel- group 1 mode active but it doesn't supports so how to solve the issue.
interface Port-channel1
 no ip address
 hold-queue 150 in
interface Port-channel1.255
 encapsulation dot1Q 255 native
 ip address 192.168.1.140 255.255.255.255
interface GigabitEthernet0/0
description Uplink to <Switch name> Gig1/0/x
no ip address
duplex full
speed 1000
channel-group 1
interface GigabitEthernet0/1
description Uplink to <Switch name> Gig2/0/x
no ip address
duplex full
speed 1000
channel-group 1
Jose Jara
Level 3
Level 3
it does not support negotiation protocols, such as PAGP or LACP, so you must configure the etherchannel manually in the HP Comware switch to match the configuration of the router.
Best Regards,
Jose.
what would be config in Cisco router & any idea what should be config at HP switch ?
acampbell
Like yourself I have been hunting to find out if a 3945 (ISRG2) can support LACP.
It seems that this family of routers and ISR-G1s can only support MANUAL Ether-channelling.
https://www.cisco.com/c/dam/en/us/products/collateral/routers/3800-series-integrated-services-routers-isr/prod_white_paper0900aecd806f698a.pdf
TOP of PAGE 7
I cant find a similar paper for ISR-G2s.
Alex
Regards, Alex. Please rate useful posts.
