Port Channel Error
pcristina
Visitor
Hi guys, i have an extrange issue with some port channels on my cisco 9300 series (stack with 4 members). I have a port channel (4 interfaces) betwenn a Cisco and a Fortinet D500 (firewall) and the issues is this:  when i have the four interfaces connected working fine with the port channel up and i unplug one of the interfaces to test the resiliency and connecti this interface back this never come up and stay on  "suspended" state. no matter what i do it only came up only if i unplug the primary cable of this port channel and plug it again. only then the first cable that i unplage come up :
example:
interface Port-channel16
description Uplinks xxxx -Zona xxx
switchport trunk native vlan 2
switchport trunk allowed vlan 2-4094
switchport mode trunk
ip arp inspection trust
storm-control broadcast level 80.00
storm-control multicast level 5.00
storm-control unicast level 85.00 65.00
storm-control action trap
ip dhcp snooping trust
end
interface GigabitEthernet1/0/47
description uplink WAN - xxxx
no logging event link-status
channel-group 16 mode active
spanning-tree bpdufilter enable
spanning-tree link-type point-to-point
spanning-tree guard root
service-policy output UPLINK-COS-1G
end
interface GigabitEthernet1/0/48
end
interface GigabitEthernet2/0/47
end
interface GigabitEthernet2/0/48
end
CRIRT0001#sho etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 18
Number of aggregators: 18
Group Port-channel Protocol Ports
16 Po16(SU) LACP Gi1/0/47(P) Gi1/0/48(P) Gi2/0/47(s)
Gi2/0/48(s)
to bring up the interface gi2/0/47 i have to unplug the interface gi1/0/47 and the same for the other one. i tried shutting down both interfaces but it doesnt woked at all.
Can somebody "please" help me with this ????
regards.
Georg Pauwen
the problem could be your Fortigate. Try and set the Cisco to channel-mode 'on' and the Fortigate to 'set lacp-mode static' (if that is not the Fortigate config already)...
balaji.bandi
What is the Logs shows? another side how is fortunate configured?
EDIT :
i was looking for the URL which was solved some time back - so edited the post. ( mode on is the other option)
https://forum.fortinet.com/tm.aspx?m=106460
BB
