port channel interface status is no operational member
Ramesh Babu
Dear Team,
Below port channel interface status is no operational member. But when we checked both interface physical status is up and running. Kindly do the needful.
Switch 1 :
# sh int port 2106
port-channel2106 is down (No operational members)
vPC Status: Down, vPC number: 264249 [packets forwarded via vPC peer-link]
Hardware: Port-Channel, address: 78da.6e0c.2d47 (bia 78da.6e0c.2d47)
Description: PPPSH01
MTU 1500 bytes, BW 1100000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
auto-duplex, 1000 Mb/s
Input flow-control is off, output flow-control is on
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth121/1/6, Eth161/1/6
0 interface resets
30 seconds input rate 11536 bits/sec, 1 packets/sec
30 seconds output rate 4504 bits/sec, 6 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 10.06 Kbps, 2 pps; output rate 7.05 Kbps, 7 pps
RX
8182448767 unicast packets 4 multicast packets 1338659 broadcast packets
8183787430 input packets 39222356980393 bytes
4096246919 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
4839299443 unicast packets 43868228 multicast packets 99651387 broadcast packets
4982819058 output packets 1903106288097 bytes
6484540 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
0 interface resets
1# sh int Eth121/1/6
Ethernet121/1/6 is up
Hardware: 10/100/1000 Ethernet, address: 78da.6e0c.2d47 (bia 78da.6e0c.2d47)
Description: PPPSH01_E0
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
full-duplex, 1000 Mb/s
1# sh int Eth161/1/6
Ethernet161/1/6 is up
Hardware: 10/100/1000 Ethernet, address: 64e9.50a2.2b87 (bia 64e9.50a2.2b87)
Description: PPPSH01_E1
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
full-duplex, 100 Mb/s
Beacon is turned off
2106 Po2106(SD) Eth LACP Eth121/1/6(I) Eth161/1/6(I)
interface Ethernet121/1/6
description PPPSH01_E0
switchport
switchport access vlan 2
spanning-tree port type edge
channel-group 2106 mode active
interface Ethernet161/1/6
description PPPSH01_E1
switchport
interface port-channel2106
description PPPSH01
switchport
VPc status
264249 Po2106 down* Not Consistency Check Not -
Applicable Performed
Switch 2 :
description PPPSH01
between which devices is the port channel configured ?
8 Replies 8
Hi Georg,
Other end is HP server.
Port-channel is LACP
Thanks & Regards,
Ramesh Babu.A.
Hi Ramesh
I often see issues with server NIC teaming when integrating them with Cisco switches. When LACP is not running on the server side, you often see the port-channels themselves in 'suspended' status.
As ypu probably know, there are several config options available on Windows server for NIC teaming. The option you want configured on all servers is "switch dependent with LACP"
Hi Friend,
Thanks for your info. I will check with my server team and get back to you.
try and configure 'channel-protocol lacp' on the Cisco member interfaces. Is there a specific reason your channel is configured as an access port and not a trunk ?
Dear Friends,
Any update ?
Thanks & Regards,
Ramesh Babu.A.
hello
this is marked as the correct answer, i little more explanation would be nice :/
Ramesh Babu
Hi Georg,
Thanks & Regards,
Ramesh Babu.A.
