Port Channel issue between VSS 2x3850 and Cross-stack 2x3850
I have a strange issue.
at the main office i have 2 3850-48XS-S with VSS stack and at the remote offic 2 3850-12XS-S cross-stack.
i want to activated a port-channel between these two stack.
when i desactivated one link for tested, it's ok
but when i desactivated the second link (after réactivated the first), nothing works.
When the 2 link is activated, there are only traffic under the first link, nothing under the second.
interface Port-channel3
 description vers-faouet
 switchport trunk native vlan 99
 switchport trunk allowed vlan 99,300
 switchport mode trunk
 switchport nonegotiate
VSS SWITCH
interface TenGigabitEthernet1/0/3    and      interface TenGigabitEthernet2/0/3
 channel-group 3 mode on
 ip nbar protocol-discovery
CROSSSTACK SWITCH
I have also test this but same problem
VSS SWITCH
 channel-protocole lacp
 channel-group 3 mode active
CROSSSTACK SWITCH
VSS SWITCH
CROSSSTACK SWITCH
 channel-group 3 mode passive
Somebody have idea for resolve my problem?
I have found the resolve issue!
i havé upgrade remote stack with:
- upgrade to 16.6.2
- activated Port-Channel mode lacp (active/active)
- activated cli « lacp rate fast » to physical Link of Port-Channel => because i have L2 provider fiber box.
13 Replies 13
Yachay
Could you paste a diagram? Especially for the cross-stack devices.
chrihussey
With both links are active what is the output of "show etherchannel 3 summary"from both switches?
With both links active what is the output of "show cdp neighbor" from both switches?
Also, without touching the physical ports, cut and paste the configs for the port-channel 3 interfaces into both switches. I say this just to make sure the physical interfaces acquire the proper configs. I have found that sometimes if you configure a physical interface and just add it to the port channel sometimes things get a little screwy and this just helps get things in line.
When i check with "show etherchannel 3 summary" and "show cdp neighbor"on all switch, all output it's ok.
I i have test without port-channel configuration, with spanning-tree enable, it's ok, no problem the second link work fine if i disable the first link.
i have cut and past configuration but same problem
but i use "case RAD" for convert ethernet to fiber, it's a fulle L2 provider equipment, it's block nothing same as a direct optical fiber.
Yachay
Please, send the following information:
For VSS:
  • sh switch virtual
  • sh switch virtual role
  • sh switch virtual link
  • sh switch virtual link port-channel
  • sh etherchannel sum
For stacked switches:
  • sh switch
actually, i can't to do the "sh" command.
You can seen the attach configuration.
Can you confirme that my vss configuration it's ok for 3850
stackwise-virtual
 domain 101
interface TenGigabitEthernet1/0/45
 stackwise-virtual dual-active-detection
interface TenGigabitEthernet1/0/47
 stackwise-virtual link 1
 interface TenGigabitEthernet1/0/48
interface TenGigabitEthernet2/0/45
interface TenGigabitEthernet2/0/47
 interface TenGigabitEthernet2/0/48
Something in your VSS configuration doesn't convince me. Normally, when you are going to use 2 interfaces to build the VSS domain, a port-channel is required, but I don't see that in your configuration.
I'd say you will need to re-check the VSS configuration.
For 3850, no port Channel for VSS
Check this: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/configuration_guide/b_163_consolidated_3850_cg/b_163_consolidated_3850_cg_chapter_010101001.pdf
Perhaps I am misunderstanding it, but read the section 'Multichassis EtherChannels', third paragraph, last phrase.
Leo Laohoo
Post the complete output to the command "sh version". I remembered seeing a bug involving etherchannels and 3650/3850.
For vss: 16.6.2
for stack: 03.07.05E
@Gilles Dellaccio wrote:
For vss: 16.6.2
CSCve29061
Do not, under any circumstances, load 16.X because it is very, very unstable.  If possible, stay with 3.6.X or 3.7.X.
- upgrade to 16.6.2
Thanks for sharing your solution.
