port-channel issues
q-le
Level 2
Level 2
I set up a port-channel trunk between a acess switch 3750 ( int gi2/0/1 and gi2/0/2) and Core 6509( int gi7/11 and gi7/12).
On the both the 3750& 6509 I configured:
interface Port-channel15
switchport
switchport trunk allowed vlan 100,103
switchport mode trunk
and config all the interfaces gi2/0/1 and gi2/0/2
interface gi2/0/1 and 2 and gi7/11 and gi7/12 as below:
switchport trunk native vlan111
switchport trunk allowed vlan 100.103
switchport mode trunl
channel-group 15 mode active
but the ports on the core g7/11 and g7/12 keep shutdown and when i do
show interfaces port-channel 15
it show the interface is shutdown.
Any advice is much appreciated.
lq
Please post the error message when it shutdown..  Also make sure you have the native vlan command under the port channel SVI's on each side.
6 Replies 6
jimmysands73_2
Level 5
Level 5
You have a period, this is incorrect, is this a typo?
Same for sw mo trunl.....
Have you verified all ints on this port channel are not shutdown (not the port channel but the ints)?
Vivek Ganapathi
Level 4
Level 4
Are all the physical interfaces up ? Please post the output of show etherchannel summary.
hi,
sorry there are a typo in the config posted.
The steps I did was:
set up 2 trunks between the 3750 and core 6509.
set these 4 interfaces to be up - establish a link.
then config the port-channel interfaces in 3750 , then 6509.
config the 4 interfaces to be on port-channels.
then i got a warning message that the 2 interfaces on the 3750 got SHUTDOWN.
and the port-channels on both switches got SHUTDOWN.
when I do show etherchannel sum -it show the port-channel is down.
I always took these configs out the switches - just in case it cause any further issues.
I can do it again if needed.
leq
I did not have native VLAN command - maybe that would cause the issues
Currently the configs and the switches state are:
6509
interface g7/11 and g7/12 - up - no port-channel config yet
port-channel15 - shutdown
3750 interface gi2/0/1 and gi2/0/2 - up - no port-channel config
NOW I config both the ints gi2/0/1 and 2 with the comand: channel-group 15 mode active
THEN, the 3750 shut down both the int gi2/0/1 and 2
the log on the 3750 is:
Jan 25 11:19:31.205 AEST: %EC-5-PORTDOWN: Shutting down Gi2/0/1 as its port-channel is admin-down
Jan 25 11:19:31.649 AEST: %EC-5-PORTDOWN: Shutting down Gi2/0/2 as its port-channel is admin-down
Jan 25 11:19:31.943 AEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan111, changed state to down
Jan 25 11:19:32.060 AEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan111, changed state to up
Jan 25 11:19:33.210 AEST: %LINK-5-CHANGED: Interface GigabitEthernet2/0/1, changed state to administratively down
Jan 25 11:19:33.654 AEST: %LINK-5-CHANGED: Interface GigabitEthernet2/0/2, changed state to administratively down
Jan 25 11:19:34.216 AEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/1, changed state to down
Jan 25 11:19:34.661 AEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/2, changed state to down
in both 3750& 6509 switches' config I did not have "switchport trunk native vlan111"
just these lines below:
"interface Port-channel15
description IS port channel
switchport mode trunk"
enable native vlan111 on both the SVI on both sides and it works beautifully.
Thanks all.
Very much appreciated
