port-channel max-bundle option
from88
Level 4
Level 4
if i have a port-channel with 4 ports in it with LACP. And i want to make two ports as a backup with max bundle command. Do that 'backuped' ports will be just "unselected" from etherchannel, o ir will be physical down ? Thanks
I don't have the LAB yet, so i cant try by myself..
Reza Sharifi
The additional 2 ports will be in LACP inactive mode.
but physicaluu they will be UP?
so they will be physically UP ?
Yes, the port should stay up physically.
