Point-to-Multipoint OSPF error
bonnushka
I have a system where the Main location has multiple branches . All the branches have their own MetroEthernet circuit on a 3650 that comes back to a single interface at the Main location's 4500. This is why it is configured as a point-to multipoint. In addition to the PtoMp, we have to seperate public and staff traffic so we use VRF  lite.  The Metro E interface at each location is configured as a dot1q trunk port with a L3 SVI for each VRF instance. There is a seperate OSPF instance for each VRF. These have been running fine since we put them in last fall but about a month ago one branch started filling the logs with this:
%OSPF-5-ADJCHG: Process 2, Nbr 2.2.2.1 on Vlan2 from DOWN to DOWN, Neighbor Down: Ignore timer expired
%OSPF-5-ADJCHG: Process 2, Nbr 2.2.2.1 on Vlan2 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
What's strange is that when I show OSPF neighbors for that VRF all the other branches show as having a Full adjacency except for  Main . The EXSTART error in every bit of documentation I can find indicates a MTU error but the base OSPF instance isn't having this problem and it's on the same physical interface. I've looked for a bug and don't see any. I rebooted the switch in question and it didn't solve the problem. Today, another branch rebooted due to a power outage and now I'm getting this error on it as well.
Please help, not sure what's causing this.
Thanks ,
Bonnushka
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 58f3.9c0b.9e01 (bia 58f3.9c0b.9e01)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
2.2.2.1       0   EXSTART/  -     00:01:59    2.2.2.1     Vlan2
2.2.2.3       0   FULL/  -        00:01:36    2.2.2.3     Vlan2
2.2.2.13      0   FULL/  -        00:01:34    2.2.2.13    Vlan2
2.2.2.4       0   FULL/  -        00:01:45    2.2.2.4     Vlan2
2.2.2.20      0   FULL/  -        00:01:39    2.2.2.20    Vlan2
1.1.1.1  0   FULL/  -        00:01:42    1.1.1.1       Vlan10
1.1.1.3         0   FULL/  -        00:01:54    1.1.1.3       Vlan10
1.1.1.13        0   FULL/  -        00:01:42    1.1.1.13      Vlan10
1.1.1.4       0   FULL/  -        00:01:54    1.1.1.4       Vlan10
1.1.1.16        0   FULL/  -        00:01:57    1.1.1.16      Vlan10
EX:
 Main Location Router:
int vlan 10
ip add 1.1.1.1 255.255.255.0
ip ospf point-to-multipoint
int vlan 20
ip vrf forwarding Public
ip add 2.2.2.1 255.255.255.0
Branches:
interface GigabitEthernet1/0/1
 switchport trunk allowed vlan 10,20
 switchport mode trunk
 speed 100
 duplex full
int vlan 10
ip add 1.1.1.2(through 20) 255.255.255.0
ip ospf network point-to-multipoint
int vlan 20
ip add 2.2.2.2(through 20) 255.255.255.0
6 Replies 6
minhda
If it's allowed to run a debug on router, please try below steps on branch router:
In configuration mode:
- enable monitor logging at debug level
- set logging rate to 1
In global mode:
- command: debug ip ospf 2 events
- command: debug ip ospf 2 packets
After that, please post the output here.
Minh
Apr 13 09:41:36: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.6 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:38: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:41:39: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.20 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:42: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:41:43: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.1 aid:0.0.0.0 chk:9318 aut:0 auk: from Vlan20
Apr 13 09:41:43: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.10 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:45: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.12 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:46: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.19 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:47: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:41:48: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.4 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:50: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.11 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:51: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.15 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:52: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:41:52: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.5 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:52: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.8 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:55: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.13 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:41:57: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:41:57: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.18 aid:0.0.0.0 chk:92D8 aut:0 auk: from Vlan20
Apr 13 09:42:00: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.2 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:01: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:42:03: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.21 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:03: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.255.1 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:04: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.7 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:06: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:42:06: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.20 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:11: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:42:12: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.10 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:12: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.1 aid:0.0.0.0 chk:9318 aut:0 auk: from Vlan20
Apr 13 09:42:14: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.19 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:15: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.12 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:15: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.235.1 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:16: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.4 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:16: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:42:18: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.11 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:20: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.5 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:20: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.15 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:21: OSPF-2 PAK  : rcv. v:2 t:2 l:32 rid:2.2.2.1 aid:0.0.0.0 chk:7E6 aut:0 auk: from Vlan20
Apr 13 09:42:22: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.8 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Apr 13 09:42:24: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.18 aid:0.0.0.0 chk:92D8 aut:0 auk: from Vlan20
Apr 13 09:42:25: OSPF-2 PAK  : rcv. v:2 t:1 l:128 rid:2.2.2.13 aid:0.0.0.0 chk:9398 aut:0 auk: from Vlan20
Thanks. Please post output of: debug ip ospf adj.
Minh
 It won't do any good now, after 3 weeks the stupid thing cleared up last night all on their own. I rebooted it for a second time yesterday morning but the OSPF flapping didn't clear up until almost 10 hours later.  When the problem was occurring the router would should Full/- adjacency with all the branches but -/- with the main router.
copy the database show ip os database , and try compare when you have that behaviour again
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
I had this type of behaviour before, using Layer 2 connection across providers and root cause was BPDUs (using different VID) of Spanning-tree.
So any error messages of Spanning-tree Inconsistent? Try use bpdu-filter on Main Router.
