Port-channel not running
Vulpic
Hello, guys. I had trouble setting up the port-channel of two Cisco 2960-S switches. The following is the configuration of two switches. Everything seems to be right, the port-channel just doesn't work out, though. Please tell me which part I have done wrong, many thanks.
Switch#show running-config interface Gi1/0/1
interface Gi1/0/1
switchport mode trunk
switchport trunk allow vlan 100, 200
channel-group 1 mode passive
Switch#show running-config interface Gi1/0/2
interface Gi1/0/2
switchport mode trunkswitch
Switch#show running-config interface Po1
interface Portchannel1
Deepak Kumar
Can you confirm that both end ports are configured in "PASSIVE" mode?
interface Gi1/0/1
interface Gi1/0/2
If both switches are configured with Passive then it will not work. A port in passive mode cannot form a port channel with another port that is also in passive mode, because neither port will initiate negotiation.
So change it from "Passive" to "Active" on any switch.
interface Gi1/0/1
channel-group 1 mode ACTIVE
interface Gi1/0/2
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
Without the EtherChannel enabled, does each of the ports actually work?
Deepak Kumar
interface Gi1/0/1
interface Gi1/0/2
interface Gi1/0/1
interface Gi1/0/2
Deepak Kumar,
