Port-channel subinterface. QoS policy. ASR 1004.
arturiuslim
Hello.
I need to restrict traffic on port-channel's subinterface to 1200Mbs. I have created a port-channel and subinterfaces on it. Then i have set a policy. I used this documentation
http://www.cisco.com/en/US/docs/ios-xml/ios/qos_mqc/configuration/xe-3s/qos-eth-int.html
But all egress traffic going through the only one interface in the channel, regardless of VLANs.
Where i did a mistake?
#show class-map
Class Map match-any class-default (id 0)
   Match any
Class Map match-all OUT (id 1)
   Match any
#show policy-map ACCESS_1200M_IN
  Policy Map ACCESS_1200M_IN
    Class class-default
     police cir 1200000000 bc 37500000
       conform-action transmit
       exceed-action drop
#show interfaces port-channel 1
Port-channel1 is up, line protocol is up
  Hardware is GEChannel, address is 2894.0fed.d0c0 (bia 2894.0fed.d0c0)
  MTU 1500 bytes, BW 3000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 58/255, rxload 31/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
    No. of active members in this channel: 3
        Member 0 : GigabitEthernet0/0/0 , Full-duplex, 1000Mb/s
        Member 1 : GigabitEthernet0/0/2 , Full-duplex, 1000Mb/s
        Member 2 : GigabitEthernet0/0/3 , Full-duplex, 1000Mb/s
    No. of PF_JUMBO supported members in this channel : 3
  Last input 00:00:01, output never, output hang never
  Input queue: 0/1125/0/0 (size/max/drops/flushes); Total output drops: 54432074
  Queueing strategy: fifo
  Output queue: 0/120 (size/max)
  5 minute input rate 365999000 bits/sec, 100882 packets/sec
  5 minute output rate 691864000 bits/sec, 102081 packets/sec
     124657405555 packets input, 62680974313797 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 1054107 multicast, 0 pause input
     141665558186 packets output, 117705126108053 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
#show runn interface GigabitEthernet0/0/0
Building configuration...
Current configuration : 175 bytes
no ip address
negotiation auto
service-policy output AGGREGATE_OUT
channel-group 1
end
#show runn interface GigabitEthernet0/0/2
no ip address
negotiation auto
channel-group 1
end
#show runn interface GigabitEthernet0/0/3
Current configuration : 170 bytes
no ip address
negotiation auto
channel-group 1
end
#show policy-map AGGREGATE_OUT
  Policy Map AGGREGATE_OUT
    Class OUT service-fragment OUT
       police cir 3000000000 bc 93750000
       exceed-action drop
interface Port-channel1.1061
bandwidth 12000000
encapsulation dot1Q 1061
ip vrf forwarding internet
ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast source reachable-via any allow-self-ping
ip flow ingress
service-policy input ACCESS_1200M_IN
service-policy output ACCESS_1200M_OUT_FRAGMENT
end
Thanks.
0 Replies 0
