Port Channel Troubleshooting
michael_prejean
I have a remote site with two switches up-linked through a port channel of 4 interfaces. Recently been trying to troubleshoot slow internet speeds at this site and stumbled upon this in my discovery, not sure if it's related but certainly thought it could be contributing to something if not the speed issues.
The port channel interface has a last input of 1 week ago, last output is fine with 00:00:00. I checked the other end of the link and that port channel interface has a last output of 1 week ago, and last input of 00:00:00. The individual ports in the channel have seemingly fine input and outputs, ranging from 0 to a few seconds ago.
Could there be an issue with the port channel that I should look into further troubleshooting? Below are command outputs from the core switch first, and then the access.
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960S-48TS-L 15.2(1)E1 C2960S-UNIVERSALK9-M
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 08cc.68f0.b9af (bia 08cc.68f0
Description: Uplink USNBSW004
MTU 1500 bytes, BW 4000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/45 Gi1/0/46 Gi1/0/47 Gi1/0/48
Last input 1w0d, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d00h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 5310000 bits/sec, 1472 packets/sec
5 minute output rate 22573000 bits/sec, 2329 packets/sec
148829716 packets input, 42859646617 bytes, 0 no buffer
Received 3290420 broadcasts (1919927 multicasts)
0 watchdog, 1919927 multicast, 0 pause input
285277214 packets output, 349110399341 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1/0/45 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 08cc.68f0.b9ad (bia 08cc. 68f0.b9ad)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Last input 00:00:03, output 00:00:02, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops : 1425
5 minute input rate 395000 bits/sec, 207 packets/sec
5 minute output rate 2856000 bits/sec, 292 packets/sec
42180093 packets input, 8336766207 bytes, 0 no buffer
Received 813827 broadcasts (474132 multicasts)
0 watchdog, 474132 multicast, 0 pause input
69362349 packets output, 84087783159 bytes, 0 underruns
5880 unknown protocol drops
interface Port-channel1
description Uplink USNBSW004
switchport trunk allowed vlan 1-60,90,96,120,150,172,192,220,240,517
switchport mode trunk
end
interface GigabitEthernet1/0/45
mls qos trust dscp
channel-group 1 mode on
end
interface GigabitEthernet1/0/46
mls qos trust dscp
end
interface GigabitEthernet1/0/47
mls qos trust dscp
end
interface GigabitEthernet1/0/48
mls qos trust dscp
* 1 52 WS-C2960S-48FPS-L 15.2(1)E1 C2960S-UNIVERSALK9-M
2 52 WS-C2960S-48FPS-L 15.2(1)E1 C2960S-UNIVERSALK9-M
3 52 WS-C2960S-48TS-L 15.2(1)E1 C2960S-UNIVERSALK9-M
Hardware is EtherChannel, address is 7010.5c8b.842f (bia 7010.5c8b.842f)
Description: Uplink USNBSW001
Members in this channel: Gi1/0/47 Gi1/0/48 Gi2/0/47 Gi2/0/48
Last input 00:00:00, output 1w0d, output hang never
Last clearing of "show interface" counters 02:00:28
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 25
5 minute input rate 26641000 bits/sec, 2693 packets/sec
5 minute output rate 5389000 bits/sec, 1708 packets/sec
19999422 packets input, 23088047070 bytes, 0 no buffer
Received 114635 broadcasts (93238 multicasts)
0 watchdog, 93238 multicast, 0 pause input
12974456 packets output, 6479931218 bytes, 0 underruns
description Uplink USNBSW001
mls qos trust dscp
end
mls qos trust dscp
end
interface GigabitEthernet2/0/47
mls qos trust dscp
end
interface GigabitEthernet2/0/48
mls qos trust dscp
balaji.bandi
That could a software bug I guess,
i can see port-channel has 4GB capacity -
here is my suggestions :
1. I see some drops here, not major clear the counter and observe is this increasing
2. Move from ON to LACP should be better since both are Cisco switches.
3. when you change LACP, shutdown the port-channel bring up, see that bug mentioned should go and you should see normal.
   - if you move to LAP, Look at the load balance methods to use :
https://www.ciscopress.com/articles/article.asp?p=2348266&seqNum=3
4. if you still see performance issue, not sure which switch is connected to outside network, so connect the device to that switch directly test is that better still have issue ?
5. since it got 4GB link, and i do not see your throughput that much, each day shutdown 1 of the port in port-channel member and check any improvements ? ( this test still you can do with out moving to LACP). so you can identify any dodgy cable issues ?
BB
