10-30-2016 07:00 AM - edited 03-08-2019 07:58 AM
Can i configure port channel using different 10 SFP model (SFP-10G-SR-S,SFP-10G-LR-S),
switch 1 gig0/1 (SFP-10G-SR-S) --------- Switch 2 gig0/1 (SFP-10G-SR-S)
switch 1 gig0/2 (SFP-10G-LR-S) --------- Switch 2 gig0/2 (SFP-10G-LR-S)
Solved! Go to Solution.
10-30-2016 07:42 AM
the physical interfaces do not matter as long as the speed is the same. So your SFPs will work fine together in a port channel.
10-31-2016 03:51 AM
As a cautionary note - make sure the SR are connected with multimode fiber, and the LR are connected with Singlemode fiber (end to end, if you have intermediate fiber patch panels).
10-30-2016 07:42 AM
10-31-2016 03:51 AM
11-01-2016 05:04 AM
Thanks gpauwen and pwwiddicombe for the support
