Secondary power supply Cisco 2921, 3925
sergeymolchanov
Hello!
I have two routers: Cisco 2921 and Cisco 3925. I want add secondary power supplies to it.
What models of power supplies I must choose?
Power supplies, that already installed in routers:
2921: PWR-2921-51-AC
3925: PWR-3900-AC
If I understand routers guide correctly, I can add to 3925 same power supply PWR-3900-AC, but 2921 support only RPS system, not secondary power supply.
chrihussey
Yes you are correct. The 3925 is pretty cut and dry.
Below are links for the RPS as that is a bit more involved. Apparently you need an adapter for the 2921 (RPS-ADPTR-2921-51) and get the correct cable for the connection to the RPS 2300.
http://www.cisco.com/c/en/us/td/docs/routers/access/2900/hardware/installation/guide/Hardware_Installation_Guide/Overview.html#pgfId-1192360
http://www.cisco.com/c/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/ordering_guide_c07_557736.html#_Toc422864894
http://www.cisco.com/c/en/us/products/collateral/switches/redundant-power-system-2300/product_data_sheet0900aecd805bbef6.html
chrihussey
