port-channel
dkblee
hi! if i;m connecting 1 edge switch to 2 core switches. (2 trunk links, 1 link to each core), how do i configure the etherchannel at the core side? can the same channel id used across the core switches? what's the configuration be like at the core side?
thx
glen.grant
   According to your description there would be no etherchannel because you are saying 1 link to each core .  You would have a simple trunk to each core .  In order to etherchannel you would have to have 2 links to each core.  Just a create a simple trunk on each end.
5 Replies 5
Jon Marshall
dkblee@hotmail.com
thx
Channel id is local to the switch so you can use the same channel-id on both core switches.,
Jon
hi! does that mean the grouping is only at the edge switch end and not the core switch? If the id is local to the core, so there isn't any need to do grouping at the core sw end? thx.
Check out the below link on etherchannel configuration on switches, hope to help !!
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swethchl.html#wp1043287
If helpful do rate the valaubale post.
Ganesh.H
krishnakumarr
hi
Pl find sample port channel config for both end cisco switches
core swith 1
interface Port-channel1
switchport mode trunk
no shut
interface fastEthernet1/1
channel-group 1 mode active
no shut
interface fastEthernet1/2
no shut
core switch 2
no shut
interface fastethernet 1/1
no shut
no shut
other switches
Use LACP mode
glen.grant
