Port channeling SX350 & SX550
JonathanPBL
Hi Guys,
Got a strange issue between our core switch SX550-48 to our edge switch SX350-48. We use 4 copper links between the edge and core in a single port channel. The core switch shows all physical links up but the edge side is down. Not sure what is going on here but we have the same config on all of our switches stack across the site which works fine.
Edge side
Load balancing: src-dst-mac.
Gathering information...
Channel Ports
Po1 Active: te2/0/1-2 Non-candidate: te1/0/1-2
te1/0/1 10G-Combo-C -- -- -- -- Down -- --
te1/0/2 10G-Combo-C -- -- -- -- Down -- --
te2/0/1 10G-Combo-C Full 1000 Enabled Off Up Disabled Off
te2/0/2 10G-Combo-C Full 1000 Enabled Off Up Disabled Off
Core side:
Gathering information......
Channel Ports
Po4 Active: gi1/0/10,gi2/0/10 Non-candidate: gi1/0/9,gi2/0/9
gi1/0/9 1G-Copper Full 1000 Enabled Off Up Disabled Off
gi1/0/10 1G-Copper Full 1000 Enabled Off Up Disabled On
gi2/0/9 1G-Copper Full 1000 Enabled Off Up Disabled Off
gi2/0/10 1G-Copper Full 1000 Enabled Off Up Disabled On
Thanks a lot!
Jonathan
Deepak Kumar
Can you check that non-candidate ports are getting suspended or not?
If Ports are in suspended mode then restart that remote switch. I am facing same issue with 550X from the last 1 year. No solution found yet.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hey Keepak,
Thanks for the reply. Can confirm that the port's are not suspended - very strange one. Tried changing the cables too incase of a physical issue.
Jonathan
Can you post  the config of the physical and pc interfaces from both switches please?
Kind Regards
Paul
Hi Paul,
Thanks for the replay. Please see below.
Edge switch
interface TenGigabitEthernet1/0/1
lacp port-priority 1000
no spanning-tree portfast
spanning-tree link-type point-to-point
channel-group 1 mode auto
switchport mode trunk
lldp med disable
interface TenGigabitEthernet1/0/2
lldp med disable
interface TenGigabitEthernet2/0/1
lacp port-priority 2000
lldp med disable
interface TenGigabitEthernet2/0/2
lldp med disable
interface Port-Channel1
Core side
interface GigabitEthernet1/0/9
description ST4-SW1-49
channel-group 4 mode auto
interface GigabitEthernet1/0/10
description ST4-SW2-49
interface GigabitEthernet2/0/9
description ST4-SW1-50
interface GigabitEthernet2/0/10
description ST4-SW2-50
interface Port-Channel4
loopback-detection enable
description Stack4
