Port-Channels L2
habana1020131
Can I create more than 24 port-channels? I need almost 50 and I don't know how to do it.
Thanks in advance..
the maximum number of port channels depends on the platform and software. Can you post the output of 'show version' of the device you want to configure the port channels on ?
This is sh version output.. it's a stack of three 2960X CISCO switch
Switch#sh version
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E3, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 26-Aug-15 07:12 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
Switch uptime is 2 days, 2 hours, 48 minutes
System restarted at 17:17:32 UTC Mon Apr 24 2017
System image file is "flash:/c2960x-universalk9-mz.152-2.E3/c2960x-universalk9-mz.152-2.E3.bin"
Last reload reason: power-on
 --More--         Importers, exporters, distributors and users are responsible for
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48TD-L (APM86XXX) processor (revision J0) with 524288K bytes of memory.
Processor board ID FCW1912A1TE
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
150 Gigabit Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Switch Ports Model                     SW Version            SW Image
*    1 52    WS-C2960X-48TD-L          15.2(2)E3             C2960X-UNIVERSALK9-M
     2 52    WS-C2960X-48TD-L          15.2(2)E3             C2960X-UNIVERSALK9-M
     3 52    WS-C2960X-48TD-L          15.2(2)E3             C2960X-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 2 days, 2 hours, 48 minutes
Base ethernet MAC Address       : F0:B2:E5:7B:A2:80
Motherboard assembly number     : 73-100640-03
Power supply part number        : 341-0531-02
Motherboard serial number       : FOC1910M9EK
Power supply serial number      : LIT191055LB
Model revision number           : J0
Motherboard revision number     : C0
Model number                    : WS-C2960X-48TD-L
Daughterboard assembly number   : 73-14200-03
Daughterboard serial number     : FOC1910V841
System serial number            : FOC1910S4Q2
Top assembly part number        : 68-100466-01
Top assembly revision number    : B0
Version ID                      : V04
CLEI Code Number                : CMMNH00ARD
Daughterboard revision number   : A0
Switch 03
Base ethernet MAC Address       : B0:7D:47:12:A9:80
Motherboard serial number       : FOC1910JV16
Power supply serial number      : LIT1910T11V
Daughterboard serial number     : FOC19103Q0L
System serial number            : FOC1910S4L8
Top assembly revision number    : C0
Version ID                      : V04
Configuration register is 0xF
Switch#
Thanks in advance
unfortunately the 2960x supports a maximum of 24 channel groups (see the attached document below):
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.html
Thanks a lot, that's was what I saw. I would have to think in other way to do it.. thanks again
