Bookmark
Subscribe
4995
Port Channerl - Mode LACP
flielguera
Hello, I will define a Port-Channel Interface in mode LACP, in a Switch Catalyst 3850:
interface Port-channel4
 switchport mode access
end
To this port-channel interface, I associate two interfaces:
interface GigabitEthernet1/0/4
 description -- PC03-ADM --
 channel-group 4 mode passive
end
YN-NW-GB06-170#sh run int g2/0/4
Building configuration...
Current configuration : 120 bytes
interface GigabitEthernet2/0/4
end
When I check the status of the interfaces, I see :
YN-NW-GB06-170#sh etherchannel 4 summ
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 4
Number of aggregators:           4
Group  Port-channel  Protocol    Ports
4      Po4(SU)         LACP      Gi1/0/4(P)  Gi2/0/4(s)
YN-NW-GB06-170#sh int g1/0/4
GigabitEthernet1/0/4 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f078.16c4.fb04 (bia f078.16c4.fb04)
  Description: -- PC03-ADM --
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:12, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 578000 bits/sec, 489 packets/sec
     6345 packets input, 808991 bytes, 0 no buffer
     Received 3591 broadcasts (241 multicasts)
     0 watchdog, 241 multicast, 0 pause input
     1674339 packets output, 183387434 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
YN-NW-GB06-170#sh int g2/0/4
GigabitEthernet2/0/4 is up, line protocol is down (suspended)
  Hardware is Gigabit Ethernet, address is f0b2.e591.d284 (bia f0b2.e591.d284)
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     138082 packets output, 26616915 bytes, 0 underruns
YN-NW-GB06-170#
I ask, this is the normal behavior of the interfaces in this mode, or I have made error.
Please your help in this matter.
Regards.
Fernando.
Check out this article:
http://anotheritblog.net/2014/08/19/windows-server-2012-lacp-nic-teaming-on-cisco-catalyst/
I think once you change it to active mode the Cisco end will be correct.
7 Replies 7
Philip D'Ath
It sounds like the channel has not formed.  Try this command to check:
show etherchannel summary
Try using active mode rather than passive mode.
Hello, thanks for the fast response, I will try to change to mode active.
This is the output of the command:
YN-NW-GB06-170#sh etherchannel summ
        d - default port
1      Po1(SU)          -        Gi1/1/1(P)  Gi2/1/1(P)
2      Po2(SD)          -        Gi1/0/1(D)  Gi1/0/2(D)  Gi2/0/1(D)
                                 Gi2/0/2(D)
3      Po3(SD)          -        Gi1/0/3(D)  Gi2/0/3(D)
YN-NW-GB06-170#
Please, do you have if any special configuration for Microsoft Server 2012 r2 and Port-Channel LACP...???
Regards.
Fernando
Thanks so much for you Help.
Regards.
Fernando.
P.Dath show you good article, according to my consideration you also need a software to download on server end. check out.
https://www.microsoft.com/en-us/download/details.aspx?id=40319
Kazim abbas
Also, thanks so much for you help.
Regards.
If your problem solved, please mark as question answered.
