Port configuration
saquib.tandel
We got  a Scenario and need advice
Port 4/1 on a catalyst switch 4506 was configured for vlan 55. Windows team needs to configure Virtual Machine on the same box and use different vlan for each VM. ( i,e - vlan 55,56,57 can be allowed to use on port 4/1 and communicate with all vlans )
Current Switch-config
vlan 55
name SDG
vlan 56
name IDG
vlan 57
name MDG
inter gigaEthernet 4/1
description connected to HyperV-server
switchport mode access
switchport access vlan 55
What i understand to allow more than one vlan the port should be configured as trunk ports. if the port is connected to a PC then configure it as an access port. On my scenario what should I configure the port.
ST
6 Replies 6
   VM(NIC support) needs to do VLAN tagging(802.1Q) for you. What you have to do is as follows:
switchport mode trunk
HTH,
Toshi
Do most NIC do tagging?  I was always under the impression that NICs cant tag, that falls on the responsibility of the switch.  And another question, by tagging we are telling the upstream switch which MAC address to assocatite to what port and what VLAN that MAC is tied to right?
Jimmy
It it mostly done in a VM environments,  where you have multiple NICs team together with multiple vlans. It is called "virtual switch tagging". ESX for example supports only dot1q.
Reza
Hi Jimmy,
      You may think of you have one phisical server that has one physical NIC. You would like to have multiple os/applications on that server. I'd call each OS/Application as guest. Let's say you would like to have 3 guests(virtual machines) on that server. You want to assign a vlan for each guest. You now need to have 3 networks/VLANs on that server. VM can create virtual NICs. You now have 3 virtual NICs for 3 guests on that server. Well, VM can also create a virtual switch. Yes,its all in software. Lets conclude what you already have in software.
1. 1 virtual switch.
2. 3 virtual NICs. 3 networks. 3 vlans. for 3 guests(OS/Applications)
3. Think of connecting  3 virtual NICs to a virtual switch. And assign a vlan to each virtual NIC. Let's say we create vlan 10,20 and 30.
4. Time to think of physical interface (real NIC on the server). You can think of we use a physical NIC as an uplink connected/bound to the virtual switch. Well, we want to carry 3 vlans out of the physical NIC to the network environment(Trunk Port). That's why we need a physical NIC to support VLAN tagging(802.1q).
HTH,
Toshi
Excellent description, thank you!!!
tmwalsh
Do this all the time, basically need to set up a trunk between the server and the access switch. You'll want to use 802.1Q for the trunk and at least in our case prune the unwanted vlans.
Server nics are capable of teaming in this day and age. Which Hypervisor are you using? Xen, Hyper-v, ESX or some other flavor? You'll want to look at their documentation to determine specific steps needed.
Also, if your using HP Proliant Servers with NIC Teaming with Hyper-v you'll want to look at the sequence for installing hyper-v and the teaming agents. The gist is that the teaming needs to be installed after hyper-v for the vlans to work properly. If you built the server using the HP SmartStart CD you'll need to uninstall both hyper-v and the teaming parts.
Promiscuous mode is also sometimes needed to get all the vlans to be seen.
