Port console / Login issue... even if i disable line con 0 !
Elrick Landon
For unknow reason, i was no more able to connect to my switch (2960X) on console port.
My current log/password seems to no more working properly.
Hopefully, Telnet access is still working.
I tried to change the password on line con 0, but it doesn't take it in count.
router#configure terminal
router(config)#line con 0
router(config-line)#password letmein
router(config-line)#login
router(config-line)#end
I tried to disable the login on console port, no effect !
router(config-line)#no login
router(config-line)#privilege level 15
But it doesn't change anything, console port still request to me a username and password :(
I paste my conf :
C2960X#1#show conf
Using 2381 out of 524288 bytes
! Last configuration change at 22:23:36 CET Fri Mar 9 2018
! NVRAM config last updated at 22:23:46 CET Fri Mar 9 2018
version 15.2
no service pad
service password-encryption
hostname C2960X#1
boot-start-marker
boot-end-marker
enable secret 5 $1$Bg75$Fudl8Qwp3cKGy*******.
enable password 7 091C***********
username Cisco privilege 15 secret 5 $1$bws3$zWXifQkSWAkdL*********
no aaa new-model
clock timezone CET 1 0
clock summer-time cest recurring last Sun Mar 3:00 last Sun Oct 3:00
switch 1 provision ws-c2960x-24td-l
crypto pki trustpoint TP-self-signed-2645615***
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2645615***
 revocation-check none
 rsakeypair TP-self-signed-2645615***
crypto pki certificate chain TP-self-signed-2645615***
 certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
 ip address 192.168.1.250 255.255.255.0
ip default-gateway 192.168.1.1
no ip http server
ip http authentication local
ip http secure-server
vstack
line con 0
 privilege level 15
line vty 0 4
 password 7 06565773491***
 login
line vty 5 15
 login
ntp server pool.ntp.org
end
Do you have any idea about what is wrong ?
Best Regards.
Richard Burts
You show us commands that you used
but the prompt/device name here does not match the prompt/device name in the config that you posted. So it looks like you did the commands on one device but posted from a different device and we have no knowledge of what was actually done on the switch whose config you posted.
Rick
Rick
