Port Disables Every 10 Minutes
TrustNetworks
Good Afternoon
I am experiencing the same problem described in this post https://supportforums.cisco.com/message/3421454#3421454
I have seen this happen on different networks, with different equipment attached. It happens on both 2960 and 3750 switches.
Basically the connection drops, and we see in the web interface "Port is Disabled". This appears to happen every 10 minutes.
On the CLI, the status shows as connected.
Port      Name               Status       Vlan       Duplex  Speed Type
Fa0/38                       connected    1          a-full  a-100 10/100BaseTX
I have ran cable diagnostics while the drop out is occuring.
Interface Speed Local pair Pair length        Remote pair Pair status
Fa0/38    100M  Pair A     28   +/- 15 meters Pair B      Normal
                        Pair B     28   +/- 15 meters Pair A      Normal
                        Pair C     N/A                Pair D      Not Supported
                        Pair D     N/A                Pair C      Not Supported
During the outage, I see the duplex flucate between full and half. The outage occurs for approx 90 seconds
If I fix the duplex and speed at both ends, the outage reduces to around 30 seconds.
If I apply spanning-tree portfast the outage reduces further to around 10 seconds.
Before I change any configuration on the port, the logs show the interface going down
Aug 16 13:06:51.875: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to down
Aug 16 13:06:52.874: %LINK-3-UPDOWN: Interface FastEthernet0/38, changed state to down
Aug 16 13:06:55.306: %LINK-3-UPDOWN: Interface FastEthernet0/38, changed state to up
Aug 16 13:06:56.313: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to up
Aug 16 13:07:28.089: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to down
Aug 16 13:07:30.094: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/38, changed state to up
However, once I apply the configuration nothing is logged. However we can still see the conneciton is disappearing for around 10 seconds.
I suspect the issue wasn't resolved for the person reporting the problem in the link above, but because the outage is minimized, and not being logged it is going unnoticed.
Does anyone know what causes this, or how I can troubleshoot further.
Paul
32 Replies 32
I just ran into the same issue with Canon imageRunner Advance C5250 which was filling up my logs on the switches with basically connecting/disconnecting every minute. It seems that power saving settings also turn off the network interface card of the device. Luckily I have found a nice workaround to change on printer "Sleep Mode Energy Use" from LOW (default value) to HIGH which might consume more power but resolved the network communication issues.
The Canon manual states that there can be network issues related to setting the value to LOW.
I don't understand why this the default setting when Canon is aware of network issues but at least there is a workaround.
Another side effect of this flapping of the port is autonegotiation. I have seen cases that it just negotiated half duplex which caused collisions on the interface, so setting agreed speed and duplex and both ends (printer and switch) is not such a bad idea at all.
Hans
ben.hassen
I ran into this issue with a iR-ADV 6055. I manually set the speed/duplex on both ends, disabled IPv6 on the printer, and removed Voice configuration from the port. It appears to have resolved the issue.
I know this is an old thread, but hopefully it can help someone else.
CoolElectricity
I know this is an even older necro than the last, but we wanted to mention that we experienced this "drops every 10 minutes" "blipping" while adding 2 x 10Gbe segments to a Cisco SG200 1Gbe "trunk" switch and we were able to troubleshoot a little easier by clearing the Interface Counters and Etherlike Counters after unplugging LAG ports until only one of the LAG port connections remained. It turns out that the issue was using the "middle switch" to connect the other segments/machines was seemingly the issue, as when we switched the port connect to the outtermost 10Gbe switch of the 2 that were added, there were no longer issues with the drops every 10 minutes.
We hope that helps others that might be keeping these older switches going in homelabs or SOHO situations were they are not DC-ed to the public web (too many CVEs...).
