Port Doesn't Continuously Broadcast MACSEC Announcements on Reboot
ldnelson16
My Cisco Catalyst 9300 is configured to initiate a MACSEC connectivity association with other devices using a Pre-shared key (PSK). All parameters are correct in the sense that an association can be made and the encryption is done correctly when done so. However, I expect that when the connection is interrupted, the Cisco Catalyst will attempt to re-initiate the MACSEC connection, however it does not at all, by sending out frames advertising its MKA ability. It only sends out these 'advertisement frames' when you reboot the port (using shutdown; no shutdown;). How do I fix this behavior? Is it possible? I have another switch which continuously tries to connect it seems, but I can't get this behavior on the Catalyst.
Here are parameters of my MKA :
mka_v2 112 FALSE 0 TRUE TRUE GCM-AES-128 Tw1/0/1 Tw1/0/2
Gi1/1/1 Gi1/1/2, which shows that DP (delay protect) is FALSE, CO (confidentiality offset) is 0, KS (key server priotity) is 112, ICVIND (include icv indicator) is TRUE, SAKR OLPL (SAK-Rekey On-Live-Peer-Loss) is TRUE, Cipher suite is GCM-AES-128, and It is applied on two interfaces.
... and MACSEC :
MACsec is enabled
Replay protect : enabled
Replay window : 0
Include SCI : yes
Use ES Enable : no
Use SCB Enable : no
Admin Pt2Pt MAC : forceTrue(1)
Pt2Pt MAC Operational : no
Cipher : GCM-AES-128
Confidentiality Offset : 0
Capabilities
ICV length : 16
Data length change supported: yes
Max. Rx SA : 32
Max. Tx SA : 32
Max. Rx SC : 16
Max. Tx SC : 16
Validate Frames : strict
PN threshold notification support : Yes
Ciphers supported : GCM-AES-128
GCM-AES-256
GCM-AES-XPN-128
GCM-AES-XPN-256
Access control : should secure
No Transmit Secure Channels
No Receive Secure Channels
Mark Elsen
 - Always useful to verify such issues against the latest advisory software version for the 9300 , if applicable ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
