Showing results forĀ
Search instead forĀ
Did you mean:Ā
Port Flapping
taro75
Level 3
Level 3
I have 9200 switch with endpoints connected to it. One particular port is frequently going up and down. [Line protocol changes state to up / down]. This port is connected to a PC. How can I identify the root cause of this failure? It's not related to spanning tree because it's connected to PC. How can I enable some debug commands for this particular interface?
M02@rt37
Hello @taro75,
do sh interface X/X command and check any errors or other thing that could conduct to L1 issue (cable)
Best regards
Richard Pidcock
Level 6
Level 6
As suggested by M02@rt37 , that would be my guess.  I'd look for indicators of a cabling issue.  Have you replaced the cable, or if possible can you test your cabling end to end with a tester?  It's possible to be house cabling vs. just a patch cord.
Richard W. Pidcock
