port forward help for remote desktop
Katsikantais
I'm having a problem with port forward for remote desktop.
My Cisco 2801 is connected as 2cd router. FE0/0 is my wan
and FE0/1 in my local.
On main 1st router I have ports 3389 (for remote desktop)
and 23 (for accessing the cisco) forward to cisco wan ip (fe0/0)
trying to connect to cisco with telnet on port 23 works ok
but remote desktop don't
Here is my config....
version 12.4
hostname XXXXXX
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret xxxxxxxxx
enable password xxxxxxxx
no aaa new-model
clock timezone UTC 2
no network-clock-participate wic 1
ip source-route
ip cef
no ipv6 cef
voice-card 0
username xxxxx password xxxxxxx
archive
log config
hidekeys
controller E1 0/1/0
shutdown
interface FastEthernet0/0
description wan.interface
ip address 172.xx.xx.xx 255.255.255.0
ip nat outside
ip virtual-reassembly
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
description local.interface
ip address 192.xx.xx.xx 255.255.255.0
ip nat inside
speed auto
half-duplex
no mop enabled
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.xx.xx.xx
no ip http server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.xx.xx.xx 3389 interface FastEthernet0/0 3389
ip access-list extended no_telnet
deny tcp any any eq telnet
access-list 10 permit 192.xx.xx.xx 0.0.0.255
access-list 100 deny icmp any any echo
access-list 100 permit ip any any
disable-eadi
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
ntp source FastEthernet0/0
end
Can you please tell me what the problem with my 2801 config.
Thank you.
23 Replies 23
Hello
Not matter if you use single/double nat or bridging you will have to append a static nat rule statement on the mikrotic rtr
As for the single nat option, second addressing on the mikrotic rtr would be required to accommodate that new subnet
Whats the reason you cannot nat or bridge on the Cisco?
res
paul
Kind Regards
Paul
I tried the bridge you suggested on cisco but I didn't make it work..
Maybe I did something wrong. I try again tomorrow.
thanks
I finaly fixed and now port forward is working.
I also added some rules to protect access to lan & router from internet
Here is my config. Any suggestions are welcome.
Current configuration : 1922 bytes
version 12.4
no service pad
service password-encryption
hostname xxxxxxx
boot-start-marker
boot-end-marker
enable secret 5 xxxx
enable password 7 xxxx
no aaa new-model
no ip source-route
ip cef
no ip bootp server
no ipv6 cef
voice-card 0
username xxxx password 7 xxxxx
archive
log config
hidekeys
controller E1 0/1/0
shutdown
ip address 1xx.xx.xx.xx 255.xx.xx.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no cdp enable
no mop enabled
ip nat inside
duplex auto
speed auto
no mop enabled
ip route 0.0.0.0 0.0.0.0 1xx.xx.xx.xx
no ip http server
ip nat inside source static tcp 1xx.xx.xx.xx 3389 interface FastEthernet0/0 3389
ip access-list standard NAT
permit 1xx.xx.xx.0 0.0.xx.xx
access-list 10 permit 1xx.xx.xx 0.0.0.255
access-list 100 deny tcp any host 1xx.xx.xx.xx eq telnet
access-list 100 deny ip any any log
access-list 100 deny tcp any host 1xx.xx.xx.xx eq 22
disable-eadi
no cdp run
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
access-class 10 in
exec-timeout 60 0
login local
end
So now your Cisco is the Internet edge device ? Or is the MIkrotik still the router actually connected to the Internet ?
Mikrotik is the edge router and cisco is the 2cd.
Had to change some rules in mikrotik first the I reconfigure cisco from start to make it work.
thanks
Hello
Glad to hear that!
FYI-
- Not required as it isnt being called by thing
<--- default acl is to deny all anyway, and after the second ace the rest of this acl will not be used and its being matched by everything.
You need to apply the most specific entries first
Example:
access-list 100 permit  xxxx etc.......( but not any any)......
access-list 100 deny ip any any log  <--- just for logging purposes
res
Paul
Kind Regards
Paul
thanks for suggestion. I fixed the rules now.
I got little confused about the rule
How exaclty should this rule be. If I change anything I dont have internet
in my PC.
thanks
Hello
i would say remove it but if you wish to control and allow certain access with an Acl on your 2nd rtr wan interface interface then a simple cbac rule can help
Example:
access-list 100 permit  icmp any any echo-reply
Ip inspect name CBAC tcp
ip inspect name CBAC udp
Ip inspect name  CBAC icmp
Interface fa0/0
description 2nd rtr wan link
ip inspect CBAC out
res
paul
sent by iPhone
Kind Regards
Paul
Hello
I can't NAT all on Cisco.
I use mikrotik to offer free wifi to customers with hotspot
and I use cisco to give internet to offices
If that the case than, you have an option to bridge the mikrotik local lan over the cisco .
Doing this will bridge the mikrotik local lan addressing to users attached to the cisco with the Port forwading set on the mikrotik rtr.
Example forcisco rtr: and no NAT
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface x/x
description link to mikrotik
bridge-group 1
interface x/x
description  Cisco lan switch
bridge-group 1
interface BVI1
res
Paul
Kind Regards
Paul
