Port forwarding cisco 1800 with pppoe
chrisgerke
Wondering if someone can share some knowledge, its the first time I've had to do this with a cisco router. I need to forward specific ports to the internal ip 192.168.1.2;
UDP 15001-15200
TCP 15001
I have a standard ADSL model set to bridged mode, a Cisco 1841 connected. Internet traffic is flowing as expected, nat works, I can ping the internal ip, I just can't get port fowarding working from external sources. My acl outside_in is working as I can enable/disable telnet to the router just fine. HELP!
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.1
ip dhcp pool GUEST
   import all
   network 192.168.1.0 255.255.255.0
   dns-server ISP_DNS_SERVER_IP_ADDRESS
   default-router 192.168.1.1
   lease 5
interface FastEthernet0
description ADSL WAN
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3
switchport access vlan 14
interface Vlan1
no ip address
interface Vlan14
description GUEST
ip nat inside
ip virtual-reassembly
interface Dialer1
description PPPoE Dialer
ip address negotiated
ip access-group outside_in in
no ip redirects
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname PPPOE_USERNAME
ppp chap password 7 PPPOE_ENCRYPTED_PASSWORD
ppp ipcp route default
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 ISP_DEFAULT_GATEWAY_IP_ADDRESS
ip nat pool port_forward 192.168.1.2 192.168.1.2 netmask 255.255.255.0 type rotary
ip nat inside source list nat_inside_out interface Dialer1 overload
ip nat inside destination list port_forward pool port_forward
ip access-list extended nat_inside_out
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended outside_in
remark Basic Firewall
permit icmp any any
permit udp any eq domain host ISP_PUBLIC_IP_ADDRESS
permit tcp any host ISP_PUBLIC_IP_ADDRESS established
permit tcp any any eq 23
deny   ip any any
ip access-list extended port_forward
permit udp any any range 15001 15200
permit tcp any any eq 15001
0 Replies 0
