Port forwarding not working
khhhhhhhh957
I have a problem with port forwarding. Is the problem with my ACL?
Does the rest of my configuration look good?
Thank you and good day !
5 Replies 5
Mark Malone
As a test if you remove the pbr from the lan interfaces does port forwarding work ?
No it still does not work.
no not that I can see no acls doing that  , I will reply further if I think of something on the original post as that's already been worked on by Paul and a Cisco engineer
With the current configuration, does the router block access from outside to inside and reverse?
Duplicate posting
https://supportforums.cisco.com/discussion/13196141/config-router-and-nat-exchange
res
Paul
Kind Regards
Paul
