Port Forwarding to Switches
NaderHussain
What are the commands for port forwarding as per the below specifications?
R4 should implement port forwarding.
a.telnet connections to 207.U.2.98 port 23 should be forwarded to S2.
b.http connections to 207.U.2.98 port 80 should be forwarded to S2.
c.ssh connections to 207.U.2.97 port 22 should be forwarded to the ssh server on S4.
IP addresses:
S2: 192.168.190.10
S3: 172.20.190.10
S4: 10.190.1.10
Please get back to me as soon as possible.
Dennis Mink
Nader,
what have you got so far?  show us your current NAT statements in your configuration and why is it failing?
Please remember to rate useful posts, by clicking on the stars below.
Attached to this message is a text file with the configs of all 3 routers. I need to know what port forwarding statements need to put in so port forwarding can work.
Leo Laohoo
Do you accept responsibility when the instructor/professor gives you a low score/grade?
