Port in suspended mode between cisco 9300 and avaya
arouna.kikone1
Hi ALL
I have two Cisco 9300X-24Y-E stacked switches. I want to implement etherchannel between my cisco switches with an avaya switch.
After the configurations and the interconnection of the switches, the port-channel goes into "suspended" mode.
Note that the cisco 9300 switch does not allow me to type the command "Switchport trunk encapsulation dot1q".
Need your help to solve this problem which prevents me from evolving in my project.
below is the ports config in etherchannel:
CONFIGURE ETHERCHANNEL LACP
SW_SI_DC_NTX(config)# interface range twentyfiveGigE1/0/23-24,twentyfiveGigE2/0/23-2/0/24
SW_SI_DC_NTX(config-if-range)#channel-protocol lacp
SW_SI_DC_NTX(config-if-range)#channel-group 40 mode active
SW_SI_DC_NTX(config-if-range)# exit
SW_SI_DC_NTX(config)#interface port-channel 40
SW_SI_DC_NTX(config-if)#switchport mode trunk
interface Port-channel 40
interface TwentyFiveGigE1/0/23
interface TwentyFiveGigE1/0/24
interface TwentyFiveGigE2/0/23
interface TwentyFiveGigE2/0/24
SW_SI_DC_NTX#sh running-config interface port-channel 40
Building configuration...
Current configuration : 68 bytes
duplex full
end
SW_SI_DC_NTX#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SD) -
40 Po40(SD) LACP Twe1/0/23(D) Twe1/0/24(s)
Twe2/0/23(D) Twe2/0/24(D)
SW_SI_DC_NTX#show interfaces twentyFiveGigE 1/0/24
TwentyFiveGigE1/0/24 is up, line protocol is down (suspended)
Hardware is Twenty Five Gigabit Ethernet, address is c02c.17fd.7e98 (bia c02c.17fd.7e98)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is on, output flow-control is unsupported
Last input 00:00:00, output 00:00:19, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 31000 bits/sec, 49 packets/sec
3603671 packets input, 382205571 bytes, 0 no buffer
Received 3455251 broadcasts (449542 multicasts)
6 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 449542 multicast, 0 pause input
12949 packets output, 1488007 bytes, 0 under runs
Output 0 broadcasts (12949 multicasts)
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW_SI_DC_NTX#
72 Replies 72
@MHM Cisco World I can to ping the devices that are connected behind the AVAYA switch but the PO state is still on "down" and "notconnected".
Won't that cause problems later?
SW_SI_DC_NTX(config)#do sh interfaces port-channel 40
Port-channel40 is down, line protocol is down (notconnect)
Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is N/A
Last input never, output never, output hang never
Show ip int brief <<- share this
@MHM Cisco World
SW_SI_DC_NTX#show ip interface brief
Vlan1 unassigned YES NVRAM up up
Vlan99 10.10.10.204 YES NVRAM up up
GigabitEthernet0/0 unassigned YES NVRAM down down
TwentyFiveGigE1/0/1 unassigned YES unset down down
TwentyFiveGigE1/0/2 unassigned YES unset down down
TwentyFiveGigE1/0/3 unassigned YES unset down down
TwentyFiveGigE1/0/4 unassigned YES unset down down
TwentyFiveGigE1/0/5 unassigned YES unset down down
TwentyFiveGigE1/0/6 unassigned YES unset down down
TwentyFiveGigE1/0/7 unassigned YES unset down down
TwentyFiveGigE1/0/8 unassigned YES unset down down
TwentyFiveGigE1/0/9 unassigned YES unset down down
TwentyFiveGigE1/0/10 unassigned YES unset down down
TwentyFiveGigE1/0/11 unassigned YES unset down down
TwentyFiveGigE1/0/12 unassigned YES unset down down
TwentyFiveGigE1/0/13 unassigned YES unset up up
TwentyFiveGigE1/0/14 unassigned YES unset up up
TwentyFiveGigE1/0/15 unassigned YES unset up up
TwentyFiveGigE1/0/16 unassigned YES unset up up
TwentyFiveGigE1/0/17 unassigned YES unset down down
TwentyFiveGigE1/0/18 unassigned YES unset down down
TwentyFiveGigE1/0/19 unassigned YES unset down down
TwentyFiveGigE1/0/20 unassigned YES unset down down
TwentyFiveGigE1/0/21 unassigned YES unset down down
TwentyFiveGigE1/0/22 unassigned YES unset down down
TwentyFiveGigE1/0/23 unassigned YES unset down down
TwentyFiveGigE1/0/24 unassigned YES unset up up
Te1/1/1 unassigned YES unset down down
Te1/1/2 unassigned YES unset down down
Te1/1/3 unassigned YES unset down down
Te1/1/4 unassigned YES unset down down
Te1/1/5 unassigned YES unset down down
Te1/1/6 unassigned YES unset down down
Te1/1/7 unassigned YES unset down down
Te1/1/8 unassigned YES unset down down
TwentyFiveGigE1/1/1 unassigned YES unset down down
TwentyFiveGigE1/1/2 unassigned YES unset down down
TwentyFiveGigE1/1/3 unassigned YES unset down down
TwentyFiveGigE1/1/4 unassigned YES unset down down
TwentyFiveGigE1/1/5 unassigned YES unset down down
TwentyFiveGigE1/1/6 unassigned YES unset down down
TwentyFiveGigE1/1/7 unassigned YES unset down down
TwentyFiveGigE1/1/8 unassigned YES unset down down
TwentyFiveGigE1/1/9 unassigned YES unset down down
TwentyFiveGigE1/1/10 unassigned YES unset down down
TwentyFiveGigE1/1/11 unassigned YES unset down down
TwentyFiveGigE1/1/12 unassigned YES unset down down
TwentyFiveGigE1/1/13 unassigned YES unset down down
TwentyFiveGigE1/1/14 unassigned YES unset down down
TwentyFiveGigE1/1/15 unassigned YES unset down down
TwentyFiveGigE1/1/16 unassigned YES unset down down
HundredGigE1/1/1 unassigned YES unset down down
HundredGigE1/1/2 unassigned YES unset down down
HundredGigE1/1/3 unassigned YES unset down down
HundredGigE1/1/4 unassigned YES unset down down
Ap1/0/1 unassigned YES unset up up
Ap1/0/2 unassigned YES unset up up
TwentyFiveGigE2/0/1 unassigned YES unset down down
TwentyFiveGigE2/0/2 unassigned YES unset down down
TwentyFiveGigE2/0/3 unassigned YES unset down down
TwentyFiveGigE2/0/4 unassigned YES unset down down
TwentyFiveGigE2/0/5 unassigned YES unset down down
TwentyFiveGigE2/0/6 unassigned YES unset down down
TwentyFiveGigE2/0/7 unassigned YES unset down down
TwentyFiveGigE2/0/8 unassigned YES unset down down
TwentyFiveGigE2/0/9 unassigned YES unset down down
TwentyFiveGigE2/0/10 unassigned YES unset down down
TwentyFiveGigE2/0/11 unassigned YES unset down down
TwentyFiveGigE2/0/12 unassigned YES unset down down
TwentyFiveGigE2/0/13 unassigned YES unset down down
TwentyFiveGigE2/0/14 unassigned YES unset down down
TwentyFiveGigE2/0/15 unassigned YES unset down down
TwentyFiveGigE2/0/16 unassigned YES unset down down
TwentyFiveGigE2/0/17 unassigned YES unset down down
TwentyFiveGigE2/0/18 unassigned YES unset down down
TwentyFiveGigE2/0/19 unassigned YES unset down down
TwentyFiveGigE2/0/20 unassigned YES unset down down
TwentyFiveGigE2/0/21 unassigned YES unset down down
TwentyFiveGigE2/0/22 unassigned YES unset down down
TwentyFiveGigE2/0/23 unassigned YES unset down down
TwentyFiveGigE2/0/24 unassigned YES unset down down
Te2/1/1 unassigned YES unset down down
Te2/1/2 unassigned YES unset down down
Te2/1/3 unassigned YES unset down down
Te2/1/4 unassigned YES unset down down
Te2/1/5 unassigned YES unset down down
Te2/1/6 unassigned YES unset down down
Te2/1/7 unassigned YES unset down down
Te2/1/8 unassigned YES unset down down
TwentyFiveGigE2/1/1 unassigned YES unset down down
TwentyFiveGigE2/1/2 unassigned YES unset down down
TwentyFiveGigE2/1/3 unassigned YES unset down down
TwentyFiveGigE2/1/4 unassigned YES unset down down
TwentyFiveGigE2/1/5 unassigned YES unset down down
TwentyFiveGigE2/1/6 unassigned YES unset down down
TwentyFiveGigE2/1/7 unassigned YES unset down down
TwentyFiveGigE2/1/8 unassigned YES unset down down
TwentyFiveGigE2/1/9 unassigned YES unset down down
TwentyFiveGigE2/1/10 unassigned YES unset down down
TwentyFiveGigE2/1/11 unassigned YES unset down down
TwentyFiveGigE2/1/12 unassigned YES unset down down
TwentyFiveGigE2/1/13 unassigned YES unset down down
TwentyFiveGigE2/1/14 unassigned YES unset down down
TwentyFiveGigE2/1/15 unassigned YES unset down down
TwentyFiveGigE2/1/16 unassigned YES unset down down
HundredGigE2/1/1 unassigned YES unset down down
HundredGigE2/1/2 unassigned YES unset down down
HundredGigE2/1/3 unassigned YES unset down down
HundredGigE2/1/4 unassigned YES unset down down
Ap2/0/1 unassigned YES unset up up
Ap2/0/2 unassigned YES unset up up
Port-channel1 unassigned YES unset down down
Port-channel2 unassigned YES unset down down
Port-channel40 unassigned YES unset down down
SW_SI_DC_NTX#
No shut PO 40
@MHM Cisco World it's always the same!!!
this interface does not make it easy for us
Ok let me check in my lab.
@MHM Cisco World
it seems to me that it is the trunk on the port that works and not the lacp. (Operational Mode: trunk (suspended member of bundle Po40))
Can you confirm this through the below outputs of the command "show interfaces twentyFiveGigE 1/0/24 switchport"?
SW_SI_DC_NTX#show interfaces twentyFiveGigE 1/0/24 switchport
Switchport: Enabled
Administrative Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 99 (JOURNAL)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
I already suspect that but need to check, PO must have MAC same as interface 1/0/24 but it not get mac.
just I need to check this point
HI @MHM Cisco World no news for my problem?
Yes I see' and it ok stand alone
But I see PO is down not up?
Can you confirm again PO up down ?
@MHM Cisco World I manage to ping the devices that are connected behind the AVAYA switch but the PO is still in "down" mode
SW_SI_DC_NTX#show interfaces port-channel 40
@MHM Cisco World how can i change the timeout in LACP to be long not short ?
Mode ON is nightmare and make loop dont do that ever' we use ON only between SW and server.
The lacp key in avaya I think issue but not so sure I dont have info about avaya alot.
in avaya which vlan allow in trunk ? same vlan allow in cisco sw trunk.
