Port Mirror
Noovi
I am having one Cisco 3850 switch and i want to know about SPAN.
monitor session 1 destinationinterface Te1/0/1
monitor session 1 source interfaceTe1/0/2
monitor session 1 source interface Te1/0/3
My question is , what is the max limit to put interface in source?
Also if i keep around 10 interface as a source then any impact on CPU utilization of the switch?
2 Accepted Solutions
Jerome BERTHIER
All is documented here :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/network_management/configuration_guide/b_nm_3se_3850_cg/b_nm_3se_3850_cg_chapter_0111.html
No impact is generaly expected but if you redirect a lot of source interfaces to the same SPAN destination thant it will be a bottleneck and you will loose packets.
Hello
You can have multiple source span ports and mirroring can cause network disruption depending how much traffic you’re mirroring - I am not saying it will cause you disruption but the potential is there for it to do so.
I would suggest when you enable your span session that keep an eye on the cpu/memory utilization of the switch, if applicable take a pre/post baseline check.
Kind Regards
Paul
Jerome BERTHIER
Thanks Jerome,Paul
Hello
Kind Regards
Paul
