Port Mirroring
markmi
Visitor
Good day,
We are implementing sniffer for traffic collection, we have 4 vlans (vlan 192,10,11 and 12) and using SG 500 model switch.
We need to monitor our traffic ingress and egress of PORT G1/1/1 (configured as trunk) and will be monitored or mirrored to port G1/1/6.
We have data collector configured in vlan 192 with ip 192.168.192.100.
Please help me to have the proper configure or network and also i can access my data collector on other vlans.
Thank you very much,
5 Replies 5
Mark Malone
Thank you very much i will be checking on it. Will update you as soon as possible.
luis_cordova
Hi @markmi
Following the guide indicated by @Mark Malone , could be something like this in your case:
I have already configure it. but i can access my collector on that port with under vlan 192. do i what config is needed to the destination port so i can access my collector.
Hi Sir,
Here's my config, but still can 't access my collector
----------Destination Port---------
interface gigabitethernet1/1/20
port monitor GigabitEthernet 1/1/24
switchport mode access
------------Source Port--------------
interface gigabitethernet1/1/24
ip dhcp relay enable
switchport trunk allowed vlan add 5,10,15,20-21,24-25,30,35,40,45,50
switchport trunk allowed vlan add 60,88,99,192
Ping Result from Core Switch
