router forward a packet through the same interface it received
Hello
is there some way to configure an router to forwarded a packet received on an interface for the same interface automatically, being that in this scenario there are two ISP and NAT configured
5 Replies 5
Reza Sharifi
balaji.bandi
we do not see any issue, what is the device you are using, have you done any config and tested ?
BB
there are an VPN service configured, when i try to connect remotelly, the router receives this conection on an interface and forwards the conection for another outbound interface, for this way i cant access the VPN. the conection has to exit for the same interface that was received
in this case we need to look at your config, can you post the config here to look please.
BB
Hello
Could you try disabling ip redirects on the routers interfaces
Kind Regards
Paul
