Port Security issue that causes limited connectivity for PCs
amr.hossam
We are facing an issue with port security here that seems to be a little bit strange. We have applied port security on some switches, with the settings set to accept maximum 2 mac addresses (for IP Phone & PC) per port, to be learned through ‘sticky’, and the violation action is to restrict access. The problem is, after applying port security, some PCs loose network connectivity and cannot obtain an IP address from the DHCP, although their mac address is correctly learned by the port and is now hard coded in the running-config. Note that there are no violations on the port and that the IP Phone connected through the same port works fine. The connectivity goes back to normal if port security settings are removed.
Did anybody face a similar issue before?
11 Replies 11
b.julin
Level 3
Level 3
Are any other features enabled?  Like arp inspection?  mab? I've never seen port security alone block traffic without a violation.
No arp inspection and MAB are not enabled, nor any other features that can cause conflict.
Antonio Knox
Level 7
Level 7
Can you post your port config?  I'd like to see the port security config.
interface FastEthernet0/11
switchport access vlan 8
switchport mode access
switchport voice vlan 201
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security mac-address sticky
switchport port-security mac-address sticky 000f.fe9f.c77f
switchport port-security mac-address sticky 000d.6536.9b66 vlan voice
spanning-tree portfast
This is a sample configuration. The mac addresses learned here are correct, even though, the PC has limited connectivity.
The switch model is WS-C3550-24PWR-SMI and the IOS Version is 12.2(50)SE.
Hello Amr,
You need to add the below configuration to the Switch port:
Interface f0/11
switchport port-security maximum 1 vlan voice
and remove the bellow configuration:
With the Sticky option, and maximum of 2 Mac allowed, you should be fine with the current config.
Mohamed
interface GigabitEthernet0/26
description "Amr Hossam"
switchport voice vlan 121
switchport port-security maximum 1 vlan access
switchport port-security mac-address sticky 0023.7d4e.ad7e
switchport port-security mac-address sticky 0021.5554.8124 vlan voice
duplex full
This is the new configuration I tried, on this switch (3560) it works fine, but on the 3550 switch the same problem still exists.
Hello Amr ,
The config is ok .
Could you check if the PC's mac address , was learned also on other secured switch port ?
Does the PC move from one to other port ?
Dan
No it doesnt move from one port to another and it is not learned on another port.
I found this in a cisco document, it says that we cannot configure sticky mac address on voice port, and should reserve 2 mac places for the IP Phone, I tried this but only 1 mac address is learned for the Phone, so this leaves an empty space which is the reason we are doing that in the first place.
• You cannot configure static secure or sticky secure MAC addresses on a voice VLAN.
• When you enable port security on an interface that is also configured with a voice VLAN, you must
set the maximum allowed secure addresses on the port to at least two plus the maximum number of
secure addresses allowed on the access VLAN. When the port is connected to a Cisco IP phone, the
IP phone requires up to two MAC addresses. The address of the IP phone is learned on the voice
VLAN, and it might or might not be learned on the access VLAN. Connecting a PC to the IP phone
requires additional MAC addresses
• If any type of port security is enabled on the access VLAN, dynamic port security is automatically
enabled on the voice VLAN.
You can find the document here http://www-europe.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea5/configuration/guide/swtrafc.pdf
I'm having exactly the same issue, in an identical network environment. Anybody has an idea?
Try the commands
clear port-security
clear mac address-table
