Port Security Violation occured, please help
muath1987
I have C3750E stack switch, When the end user try to transfer large volume of data the port goes to error-disable state!! the MAC address that appear in logs seems fake MAC"54ee.0000.0000 ". can  anybody help me why this is happen?
Interface Configuration:
interface GigabitEthernet1/0/39
switchport access vlan 335
switchport mode access
switchport nonegotiate
switchport voice vlan 316
switchport port-security maximum 2
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
Switch logs:
Aug  6 08:13:02.078 UTC: %PM-4-ERR_DISABLE: psecure-violation error detected on Gi1/0/39, putting Gi1/0/39 in err-disable state
Aug  6 08:13:02.221 UTC: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 54ee.0000.0000 on port GigabitEthernet1/0/39.
Aug  6 08:13:03.219 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/39, changed state to down.
Peter Paluch
What I suggest checking first is the output of show interface gi1/0/39 and show interface gi1/0/39 counter error - check whether you see any counters that would indicate that corrupted frames may have been received. If there are non-zero error counters for this interface, we need to eliminate the usual suspects - replace the cable, try moving the host to a different port, try replacing the NIC in the host.
If there are no errors recorded in the counters, there is still a possibility that the NIC driver on the host is buggy, and under high load conditions, it generates Ethernet frames with an incorrect MAC address. This would be more difficult to prove but is still a possibility.
I wonder - is there any virtualization software running on the host? Is the host a virtual machine itself?
Best regards,
Peter
Hi Peter
Thank you so much for your clarification, regarding the end point its Dell PC running Windows 7.
