Port-Security with a router switch module (i.e. HWIC-4ESW)
qbakies11
I have a 1941 that I am going to deploy with a HWIC-D-9ESW switch module (I only need 3 switch ports but need the PoE).  I am going to hang a 1262 autonomous AP off one of the ports but I need to configure MAC address port-security so that only that AP can pass traffic.  I know the switch modules are 'almost' exactly like a switch for commands but I can't seem to enable or configure any port-security settings.  Is port-security no available on the switch modules?
Router IOS is CISCO1941-SEC/K9 running IOS 15.0(1)M2.  I found the following article on configuring the switch modules but it doesn't say anything about port-security.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/esw_cfg.html#wp1046695
Reza Sharifi
There is a Command in the same link you provided to enable port security for vlans.
The following example shows port security being configured in the MAC address table.
Router(config)# mac-address-table secure 0000.1111.2222 fa0/1/2 vlan 3
Router(config)# end
Reza Sharifi
Router(config)# end
So once I input a MAC address as 'secure' and assign it to a port and vlan only traffic from that MAC is allowed on that port?  There are no other commands to enable this?  What happens if a different MAC does try to pass traffic on that port?
Never test this before, but I think if a different MAC address try to pass traffic, it will disable/or put the port in errodisable mode.
