Port security with devices connecting to multiple ports
win2kseries1
Experts,
With port security enable, how can we allow a device to move around and connect to different ports on the same switch without locking up the port? We have devices that need to be able to move around. As we know with port security, once MAC is registered to one port already, it will not be able to connect to another port (on the same switch). Is there a work around for this?
Thanks!
HsT
5 Replies 5
marce1000
 - If you need these Network Access Requirements , you need NAC access control (too) , and look into solution such as authenticating devices with and or using Cisco ISE (policies) - e.g/etc.
 M.
one workaround
config the MAC dynamic port-secuirty learning
decrease the aging of mac of port-secuirty mac time to be 5 min
this make mac remove from port and you can connect PC to other port and in same you dont disable port-security
test this in one port then if success apply to all.
Hello
Can you confirm what port security you have running please?
Kind Regards
Paul
Hello
Increase the max number of secure mac addresses on the port
int ran x/x-x
switchport port-security maximum x
Kind Regards
Paul
Jitendra Kumar
the best way to switchport port-security maximum x.
Jitendra
