02-08-2019 09:08 PM - edited 03-08-2019 05:17 PM
Hi everyone, I have a weird issue going on in our data center. I recently upgraded the network module on a cisco switch from 4|1gb ports to 2|1 GB 2|10Gb. The 2|1gb are shut. I did create an etherchannel/portchannel to the aggregation cores switches with 2|10GB ports. Everything is working like a charm except that a couple of hosts in the vmaware environment do have an intermittent connectivity. Infrastructure engineers think that it was due to my recent upgrade. How can I validate that there is nothing wrong with the switch. They said that the reason may be because I am running LACP on the etherchannel. We have a few servers/services on this switch and the only thing having issues is these vmware hosts.
#show int gi6/1/1
GigabitEthernet6/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 442b.036f.73b1 (bia 442b.036f.73b1)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is Not Present
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
#show int gi6/1/2
GigabitEthernet6/1/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 442b.036f.73b2 (bia 442b.036f.73b2)
Keepalive not set
#show int port-channel6
Port-channel6 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 442b.036f.73b5 (bia 442b.036f.73b5)
Description: ** ETHERCHANNEL TRUNK TO CORES **
MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s, link type is auto, media type is unknown
Members in this channel: Te6/1/1 Te6/1/2
Last input 00:00:00, output 00:04:34, output hang never
5 minute input rate 8332000 bits/sec, 2112 packets/sec
5 minute output rate 12625000 bits/sec, 2375 packets/sec
16932679777 packets input, 6341412374696 bytes, 0 no buffer
Received 56461736 broadcasts (37295298 multicasts)
0 watchdog, 37295298 multicast, 0 pause input
44351494500 packets output, 50604476180411 bytes, 0 underruns
#show ether summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
6 Po6(SU) LACP Te6/1/1(P) Te6/1/2(P)
02-08-2019 10:36 PM
- How is the intermittent connectivity experienced ? Also activate status logging on the ports of the etherchannel with logging event link-status. Check the switch logs on a regular basis (show logging) and or configure a syslog server to collect logging-data from the switch.
M.
02-09-2019 07:22 AM
Marce, the switch does not show any log errors. The ports lights stay solid green (no orange or on/off).
Per Infrastructure Engineers, within vmware, one or two hosts only out 20 or so goes green and yellow (no available) Then it will become available. This behavior is not within minutes..the hosts may show down or up within hours.
02-08-2019 11:20 PM
02-09-2019 07:18 AM
02-09-2019 07:24 AM
interface TenGigabitEthernet6/1/1
description ** ETHERCHANNEL 6 TO CORES **
switchport trunk native vlan xx
switchport mode trunk
switchport nonegotiate
channel-group 6 mode active
interface TenGigabitEthernet6/1/2
02-09-2019 07:56 AM - edited 02-09-2019 07:56 AM
To validate the Portchannel is not an issue, you can change the mode from LACP to mode On/On.
The other thing you may want to look at is the criteria for load balancing. I think the 3750 is source mac but the VMs are source IP.
02-09-2019 09:45 AM
Thanks Reza, do I do this int the portchanel or at the interfaces? do you know the specific command?
02-09-2019 10:08 AM
You would have to switch from LACP to On/ON in a maintenance window as it is disruptive.
So, under each interface, you negate the LACP first and than add mod on.
example
config t
no channel-group 6 mode active
channel-group 6 mode on
Make sure to negate it on both interfaces first if not you will see an error.
02-09-2019 10:12 AM
One more thing. Make sure to do one change at a time. Do the Portchannel first and then test with the VM guys.
If that does not help, you may want to look at the load balancing criteria next and test.
02-09-2019 08:14 PM
Reza,
when you said "Make sure to negate it on both interfaces first if not you will see an error" you imply to do the command on both interfaces on the same switch (6/1/1 and 6/1/2), but no changes are needed at the core/aggregation switch?
thank you
02-10-2019 08:05 AM - edited 02-10-2019 08:07 AM
it needs to be applied on both core/aggregation and as well as the other side. So, 6/1/1,6/1/2 and whatever interfaces these 2 interfaces connect to. So, negate all 4 interfaces on both sides and then add mode ON/ON on all.
Please remember that the change is disruptive and should be performed in a maintenance window and not during production hours.
03-26-2019 07:41 AM
Just want to let everyone know that after removing the LACP etherchannel, the issue with vmware hosts disconnecting continued. I did rebuild the etherchannels on LACP ( this is what vmware recommends anyway).
07-22-2022 12:18 AM
Hello @maraica
We are experiencing similar problems, did you find a solution in the end and if so what was it ?
Thank you
