Port Security With Dynamic Desirable Port
Ali Hazim
Why Can't Port-Security Be Configured On a Dynamic Desirable Interface (Default), Why Must The Interface Be Configured As Access Or Trunk, I Can't See The Relation Between Port-Security And VLAN, Shouldn't I Be Able To Configure Port-Security Without Changing The Default VLAN Configuration Of an Interface?
Thank You In Advance.
Mark Elsen
 So , which error are you getting when you try this ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
This Is The Error I'm Getting, Also This Is Mentioned In Cisco's Official Get Cert And All Over The Internet, But I Haven't Seen Any Explanation To Why It's Rejected.
Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/31sg/configuration/guide/conf/port_sec.pdf
 Step 2 Switch(config-if)# switchport mode access Sets the interface mode.
Note An interface in the default mode (dynamic
desirable) cannot be configured as a secure port
M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks For Your Reply, But This Is What Confuses Me, Why a Dynamic Desirable Interface Be Configured With Port Security?
