Port side intake vs. Port side exhaust
mmmartin823
Hello everyone,
Can someone explain to me the difference between Port side intake and port side exhaust on a switch?  Also, please let me know in which scenarios we might choose one over another?
Thank you!
Reza Sharifi
This scenario usually applies to Cisco Nexus Series switches, where the exit for hot air from the switch could be in the back or front side.
So, port side intake means the cold air enter the switch where the ports are and port side exhaust means hot is exiting from the port side. With Nexus switch you have the option to intake in front or the back.
For more info refer to this document:
Standard-airflow fan: This option provides front-to-back airflow, with ports aligned with the hot aisle (port-side exhaust). This option is ideal for ToR deployments to align the fabric extender ports with the server ports in a given rack
• Reversed-airflow fan: This option provides back-to-front airflow, with ports aligned with the cold aisle (port-side intake). This option is ideal for network rack deployments in which various network equipment ports need to be aligned
Link:
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-2000-series-fabric-extenders/product_bulletin_c25-680197.html
Hi Reza,
Even if it's an old thread, i see that the refered document reverse the definitions, it should be instead:
front-to-back airflow, with ports aligned with the cold* aisle (port-side intake*)
back-to-front airflow, with ports aligned with the hot* aisle (port-side exhaust*)
do you agree Reza.
