Port status in 3750 Switch
raju
Folks,
What will be the port status (L3 or L2 port)by default in 3750 and 3550 switches ?.
Appreciated for ur reply.
Raju
ankbhasi
Hi Raju,
All the ports by default are layer 2 ports and set for dynamic desirable mode which will try to form a trunk with the connected device.
Ankur
*Pls rate helpfull post
Thanks. How abt in 6509 ?
ankbhasi
Hi Raju,
If it is having NATIVE IOS then all the ports are Layer 3 ports by default.
Ankur
*Pls rate all helpfull post
