Portchannel and dual ISP
songwh911
I have a rather basic question about portchannel and dual ISPs. I have a Active/Passive ISPs where ISP2 is only active when ISP1 fails.
On ASA side, I have 2 subinterfaces with different IP address and vlan (999 for ISP1 and 998 for ISP2) assigned to each subinterfaces.
On switch side, I have access vlan 999 towards ISP 1 modem and access vlan 998 towards ISP2 modem. For portchannel towards firewall, I have a portchannel setup as trunk and allow vlan 999 and 998. But I'm unable to ping the ISP1 from firewall. I don't even see the ISP1 ip address in firewall ARP table.
On a side note, I also have a native vlan set as 999 (ISP vlan) towards some other switch from inherited config, which I want to clean up later. I wonder if that has anything to do with this issue.
Is it my portchannel configuration or native vlan configuration that's messing up with connection?
dperezoquendo
If you're not using the vlan 999 as the native between the switch and firewall trunk, then I don't think it is the issue.
I would recommend doing a packet-tracer on your ASA to narrow down the root cause.
