Portchannel dropping packets due to load balancing?
lowfell
Level 3
Level 3
I have a L2 portchannel between a 9407 and two Nexus 5000
We have Exfo testers at each end.
My port one on 9407 goes two port two on his nexus and I loop his port two.
He does the opposite. He port one loops my port two and we both send a 1Gig Down the link.
However I seem to be losing half a gig traffic either side.
I believe this is to do with the portchannel load balancing.
I've gone through all the load balancing options on the 9400 and it hasn't made any difference.
1. Do I need to set the same otions on the nexus?
2. Is it something else other than load balancing?
balaji.bandi
Can you post both the side configuration to have a look. what kind of spanning tree, where is the root bridge ?
BB
Sergey Lisitsin
lowfell,
Can you please share the actual connection diagram? I'm not sure I understand your layout correctly.
I'm actually home now so can't show you. However, basically
we have two Nexus 5000s with vpc between them
Then both nexus have a single interface in a vpc between them going to a portchannel with two interfaces on the 9407
To test I have two ports in the same vlan10 on the 9407
There are also two ports on the nexus in vlans
From port 1 on the 9407 I send to port 2 on the nexus and I loop his port.
The nexus sends traffic from his port 1 and loops port 2 on the 9407.
When we look at the test results. We are sending a Gig but only getting half gig back. I hope this is a little clearer?
