Portchannel issue with ESXI
grapevine
We have 3 cisco switches in stack, two are IE-9320-26S2C and one IE-9320-24T4X with firmware 17.18.01(IE9K_IOSXE) . There are two esxi connected to this stack using port channel. One portchannel has ports from switch 1 and switch 3 and the other has ports from switch 2 and switch 3 in the stack. When we reboot one of the switches, let say switch 1, when it gets added to the stack, we lose connectivity to ESXI, ESXI has configured NIC bonding as active active and on the switch side it is channel group mode on. Please advise how to fix this issue.
We could see the mac on the switches but no arp where the layer vlan is created (firewall)
10 Replies 10
Enes Simnica
hello @grapevine. Since ESXi is running active/active, but the switch side is using a standard LACP/static port-channel, the hashing/forwarding can break during a member reload, which is why you see MACs but no ARPs getting through.
try some stuff like:
  • On ESXi, set the NIC teaming policy to Route based on IP hash (needed for true port-channel).
  • On the switch side, make sure the port-channel is running LACP (mode active) and not just on.
  • Double-check stack consistency and that all member switches have the same IOS XE version/config.
and check this: Layer 2 Configuration Guide, Cisco IOS XE Cupertino 17.7.x (Catalyst 9300 Switches) - Configuring EtherChannels [Support] - Cisco
-Enes
CCNP x2 Enterprise
Your Friendly Networking Ninja
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
On ESXi,  the NIC teaming policy is set to Route based on IP hash.
We have standard vswitch so we cant do LACP
All switches have the same IOS XE version/config
M02@rt37
Hello @grapevine
please share port-channel configuration (Po + interfaces) on your switches. If you have "mode on" please try "mode active".
On ESXi side, you have vsphere distributed switch or standard vswitch ?
Best regards
On ESXi side, we have a standard vswitch
please reply me to your old post
MHM
OK @grapevine
Thanks for that clarification
Best regards
Hope issue is solve now
MHM
Sorry for the late response, we have added spanning-tree portfast trunk to the etherchannel config, we will test again and let you know if this fixes the issue
How you will test it?
This issue always happened?
MHM
We powered off switch one by one in the stack, then noticed if the ESXI was reachable. the issue was that once the switch got added to the stack, the ESXI went unreachable
We figured out the issue. We issued the command spanning-tree portfast trunk on the portchannel and the issue resolved
We also had an issue with SFP that connected to ESXI2, we replaced it and it resolved.
Thank you all for the support
