Portfast and network loops
CrackedJack1
What happens if there's a loop created between two ports that are set to portfast? I was under the impression that the switch will still detect the loop and shut the ports but it may take 2-3 seconds. Is this correct or does it take longer/not detect the loop at all?
Would all switches, regardless of whether they were Cisco or not, behave the same way as long as STP and portfast/edge port are set?
6 Replies 6
Mark Malone
Hey
You should run bpduguard with portfast that will put it into errdisable if someone plugs something in they shouldn't , portfast sets the fwd straight away the guard bit prevents the loop , bpdus are seen coming in the port will go errdisable with guard enabled
These 2 commands are recommended to be ran together for that purpose
double post
Ok so to answer the question: yes, two portfast ports connected together will still detect the loop after spanning tree does its thing... Assuming the broadcast storm doesn't kill the switches first:
The problem you have, is that you could potentially overwhelm the switch with a broadcast storm in the few seconds before spanning tree blocks the port (so in the few seconds between you looping the port-fast ports and spanning tree blocking the link, the broadcast storm overwhelms the switch).
This is why bpduguard is good, as it will *immediately* block the port before a broadcast storm occurs.
99% of network loops we see are between access ports (users plugging wall socket 1 into wall socket 2 by accident)...  just always run bpduguard on portfast ports :)
Thanks. So I'll be ok with portfast and loops provided the switch doesn't die from the traffic within 2-3 seconds.
With the bpduguard guard in place, along with portfast, intentionally connecting two switches together (not in a loop) would set the port to disabled though, correct?
If you connect a switch to a port with bpduguard the port will go errdisable as soon as it receives the bpdu
portfast is just to expedite it to fwd mode in stp , guard protects the port from becoming an issue
bpduguard puts the port into error-disabled state. If you are worried about extra administrative work having to no-shut a port, you can have the switch automatically recover from error disabled after a time period:
errdisable recovery cause bpduguard
errdisable recovery time 120
^ This will auto-recover the port after 2 minutes. It will instantly re-disable if the loop is still there, but assuming the user removes the loop after he/she realises he has broken things, they will automatically start working again.
