Possible to Temporarily Shutdown DHCP Pools?
Matthew Martin
Level 5
Level 5
Hello All,
Device: WS-C2960X-24PS-L
Version: 15.0(2a)EX5,
I was wondering if I have the configuration that you see below. And I want to temporarily "shutdown" the DHCP Pools configured on this switch, can I just do a "shutdown" on the corresponding Vlans below to disable the DHCP Pools? And then when I want to turn it back on just do a "no shut" on those Vlans to re-enable the DHCP Pools? Or do you have to remove the DHCP Pools completely..?
I thought I remember reading that somewhere, I just couldn't remember where it was, or if it was true or not...
Configuration:
	ip dhcp pool PCs
	 network 10.9.1.0 255.255.255.0
	 default-router 10.9.1.2
	 dns-server 192.168.15.35 10.70.1.3
	 domain-name example.com
	ip dhcp pool PHONES
	 network 10.9.2.0 255.255.255.0
	 default-router 10.9.2.1
	 option 150 ip 10.11.11.8 10.12.11.9 10.11.11.9
	interface Vlan1
	 description PCs and printers
	 ip address 10.9.1.2 255.255.255.0
	interface Vlan2
	 description Voice VLAN
	 ip address 10.9.2.2 255.255.255.0
Any thoughts or suggestions would be greatly appreciated.
Thanks in Advance,
Matt
Harsha A.
Hey Matt,
Are you planning to disable both the DHCP scopes ?
If yes, then you could disable the DHCP service on the switch using "no service dhcp" without touching your DHCP pool.
-Harsha
Harsha A.
Hey Matt,
-Harsha
Hey Harsha, thanks for the reply, much appreciated!
Yes, I plan on bringing down both Pools... But, only need to bring them down temporarily so your idea might work even better. Excellent thank you, I'll give that a try..!
Thanks Again,
Matt
