Power cables - For Cisco devices
cknox1
Hi All,
is there a specific link for where I can find out about the specific power cords which are needed for the devices, in terms of the correct part numbers etc....
I have a few devices which do not have cables, but I don't know where I can get the specific part numbers.....
Any help would be great!
If it is just the mains cable you are after, as a rule of thumb if the PSU is 350W+ it will need a "notched" cable aka, IEC C15 . Higher wattage PSUs will require a cable with a 13A rating, all others can use 10A.
For all lower wattage supply a standard IEC C13 cable will fit.
Cisco won't list part numbers for these cables as they are so ubiquitous. If they did have a part number I would be terrified to ask what the list price was! :)
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi there,
Most enterprise cisco devices will have a hardware configuration guide, and a section dedicated to power supply installation. This will provide the information you are after.
What devices are you using?
cheers,
Seb.
Hi Seb,
Thanks for the quick response - Unfortuanetly these devices are being re-used so the original boxes manufactures guide etc are not available.
Cisco 3560 Layer 3 switches and Cisco 2960 Switches - The cables are the same, but I just need the specific part number...
cheers,
Seb.
Hi Seb,
Thank you very much! This is what I was looking for c14 and c15 - That will do, as now I will just determine what the other end needs to be depending on what country they will be in.
Thank you very much for your help!
which country are you in ? Do you need the adapter AND the cable ?
