Power Controller reports power Imax error detected...
dmorassut-sbi
Community Member
Does anyone know what this means?
Here's the complete log (the err-disable and then re-enabling of the port):
001798: Aug 31 17:49:19.809: %ETHCNTR-3-LOOP_BACK_DETECTED: Keepalive packet loop-back detected on FastEthernet0/14.
001799: Aug 31 17:49:19.809: %PM-4-ERR_DISABLE: loopback error detected on Fa0/14, putting Fa0/14 in err-disable state
001800: Aug 31 17:49:20.813: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/14, changed state to down
001801: Aug 31 17:49:21.817: %LINK-3-UPDOWN: Interface FastEthernet0/14, changed state to down
001802: Aug 31 17:49:21.817: %TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/14, port set to untrusted.
001803: Sep 4 11:32:34.594: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/14: Power Controller reports power Imax error detected
001804: Sep 4 11:33:01.831: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/14: Power given, but link is not up
001817: Sep 4 16:03:11.558: %LINK-5-CHANGED: Interface FastEthernet0/14, changed state to administratively down
001818: Sep 4 16:03:13.618: %LINK-3-UPDOWN: Interface FastEthernet0/14, changed state to down
001819: Sep 4 16:03:17.758: %LINK-3-UPDOWN: Interface FastEthernet0/14, changed state to up
001820: Sep 4 16:03:18.758: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/14, changed state to up
001821: Sep 4 16:03:21.850: %TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/14, port trust enabled.
Dennis
szahid
Level 8
Level 8
Which platform is it and software version ? And what type of POE devices are in use. We have seen this issue in the past because of ESD ( Electro Static Discharge ) specially seen in the IP phones when they are used with the headsets. One thing you can try is to remove the headset ( if one is being used ) and see if the phone powers up. The message itself is complaining about the fact that more power is being drawn then the port can allow.
Thanks for your help. Not sure if a headset is attached, but I'll check. As for the other questions, here you go:
3550-02-pwr#sh ver
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(19)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 09-Dec-03 03:21 by yenanh
Image text-base: 0x00003000, data-base: 0x0080DDAC
ROM: Bootstrap program is C3550 boot loader
3550-02-pwr uptime is 27 weeks, 1 day, 20 hours, 34 minutes
System restarted at 18:16:42 AST Sun Feb 25 2007
System image file is "flash:c3550-i5q3l2-mz.121-19.EA1a/c3550-i5q3l2-mz.121-19.E
A1a.bin"
cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes
of memory.
Processor board ID CAT0731R0W8
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0D:BD:1D:C0:80
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT07300GS7
Power supply serial number: LIT0721006U
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0731R0W8
Configuration register is 0x10F
3550-02-pwr#sh power inline
Interface Admin Oper Power Device Class
(Watts)
Fa0/1 auto off 0.0 n/a n/a
Fa0/2 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/3 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/4 auto off 0.0 n/a n/a
Fa0/5 auto off 0.0 n/a n/a
Fa0/6 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/7 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/8 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/9 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/10 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/11 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/12 auto off 0.0 n/a n/a
Fa0/13 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/14 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/15 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/16 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/17 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/18 auto off 0.0 n/a n/a
Fa0/19 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/20 auto on 6.3 Cisco IP Phone 7970
Fa0/21 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/22 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/23 auto on 6.3 Cisco IP Phone 7960 n/a
Fa0/24 auto off 0.0 n/a n/a
