routing issue
greg-bnets
Hi there my network connection is as follow:
LAN--->FW--DMZ--FW--X(2610 router)---Internet
I want add a second internet connection. This would be on the same switch the 2610 is on. Now i want all my servers in the Lan to have the second connection as the gateway to the internet. How can i group them en establish this? Thanks a lot. FW = Pix Firewall
hussainratlami
Community Member
can u give more details of ur network diagram,
Hussainratlami,
Thanks for your reply. Our local LAN consists of workstations and Servers (1 subnet). Our DMZ consists of our mail servers. The DMZ is in between 2 firewalls the outside Firewall sits on the same subnet as the 2610 router which is connected to an internet leased line. I want to add another leased line to 2610 with more bandwidth. Now i want all my servers on the LAN to have the second connection as the gate way. I use NAT in the DMZ. what is the best way to achieve this?
you can use PBR for this
Request a new LAN pool from the service provider for the 2nd link
configure the NAT to this pool for the servers
Now configure PBR on your router and divert all the traffic that is sourced from the above subnet to the new link still maintaining the default route on the old link
eg.
interface fa 0/0
Description " inside interface to FW"
ip address
ip policy route-map test
access-list 111 permit ip any
route-map test permit 1
match ip address 111
set ip next-hop
ip route
HTH, rate if it does
Narayan
Narayan, Attached you can see our current and proposed topology. I want the servers on our internal LAN to connect to the Internet 2 while the workstations still use internet 1. We use private addresses on the LAN of course. I this clear?
