Power Controller reports Short detected
Dear All,
                  I am facing the below issue in my 3650 switch, Kindly help us resolve this?
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/35: Power Controller reports Short detected
Bala
9 Replies 9
Leo Laohoo
Do this:
1.  Command:  test cable tdr int Gi1/0/35;
2.  Wait for 5 to 7 seconds;
3.  Command:  sh cable tdr int Gi1/0/35; and
4.  Post the output to #3.
Please find
TDR test last run on: March 30 08:47:45
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/35 auto Pair A N/A N/A Normal
                       Pair B N/A N/A Normal
                      Pair C N/A N/A Normal
                      Pair D N/A N/A Normal
If that's "Normal" how come the speed is "auto"?
yeah , its auto only, please find the below for your reference
DIR-G-SW-3650-01#sh int gi1/0/35
GigabitEthernet1/0/35 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 00c8.8b70.2723 (bia 00c8.8b70.2723)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
No output packets.  No input packets.
Is there anything plugged into this port?
yes leo, nothing has been connected to the port, from the port one cable has been connected to patch panel only.
Temporary i was removed the cable from the switch port,after that no issues found.
So why bother running a TDR if nothing is connected to the port of the switch?
Why would I get the flood of these alarms for a port that doesn't have anything connected?
Feb 12 00:13:13: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:14:33: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:17:13: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:19:00: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:20:10: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:22:21: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:22:50: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
Feb 12 00:23:19: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/12: Power Controller reports Short detected
GigabitEthernet1/0/12 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 002a.10b8.788c (bia 002a.10b8.788c)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Last input 3d02h, output never, output hang never
Queueing strategy: Class-based queueing
251703 packets input, 32819787 bytes, 0 no buffer
Received 5787 broadcasts (4874 multicasts)
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 4874 multicast, 0 pause input
3463525 packets output, 454687863 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Hello christopher.johnson@mci.com,
My suspicion: the cable, from the switch to the patch panel, likely had one or more defective pairs that intermittently produced a short.
Your log messages don't include any information about the interface changing state from down to up, but if it had shown this transition, then it could also be that a cable was plugged into the other side of the patch panel appearance, and that cable had one or more defective (shorted) pairs.
fjm / vrs
@ittybittypacket
